0 Members and 61 Guests are viewing this topic.
ltseung888
11. What improvements do you expect to make to the technology?
Improvement 13
Building the Lead-Out Energy Bicycle
If the Lead-Out Energy Theory is correct, we should be able to a bicycle that lead-out gravitational and/or electron motion energy.  The bicycle peddle can provide the starting power and can occasionally provide energy from the human body.
This will focus more on extracting energy from the axle.  This area of research has not been done by our team yet.  We know that it is possible theoretically.  There is much more engineering work that needs to be done.
It would be interesting to have such a bicycle competing in the Bicycle Races.
Improvement 14
Building the Lead-out Energy Car
If we can build the Lead-out Energy Bicycle, we should be able to build the Lead-out Energy Car.  Rumor says that the 225 HP Pulse Motor and Liang had cars running on their engines.  The 225 HP Pulse Motor can climb steep hills as most of the lead-out energy comes from electron motion.  The Liang car cannot climb steep hills as most of the lead-out energy comes from gravity.
One possibility is the use of the Tong Wheel as the battery charging mechanism.  The typical car user drives the car to the office; parks it in a garage for many hours; drives home and lets the car rest for the night.  Even if the Tong Wheel cannot deliver 225 HP, it may be useful in the recharging of the batteries function.  The charging function can go on while the driver is away from the car.
This possibility will be investigated fully after we have the 5 KW electricity generator.
(to be continued)
ltseung888
Improvement 15
Preparing to build the Flying Saucer
The propulsion system for the Flying Saucer will be different from the known plane or rocket technology.  The known plane technology relies on pushing air away with a propeller or burning fuel to push hot gases to provide thrust.   In outer space, we do not have air.  If we rely on burning fuel, we need to carry a large amount of fuel.
We need another type of propulsion system.   This type of system has already been demonstrated by the jumping tubes of Tong on youtube.
http://www.youtube.com/watch?v=SA5ObshvNx0
http://www.youtube.com/watch?v=-TfwKBdmRao
The theory is that we can produce a net force within a closed system if we allow unequal exchanges of Energy.  The first example was the passing of current to a coil to repel two identical magnets A and B in a tube.  Magnet A is allowed to strike a hard surface producing force F1.  Magnet B is allowed to stick a soft surface producing force F2.  Since F1 is greater than F2, the tube will move in the direction of F1.  The two magnets can then be attracted back slowly into the initial position to repeat the process again.
http://www.youtube.com/watch?v=JCHOkR-S800 (Generating unbalanced force from within)
Instead of using one coil and two magnets, Mr. Tong Po Chi used two coils and one magnet to achieve the equivalent.  The result was clearly demonstrated in the above youtube videos.  Magnetic attractions can be used so that there is no need for the magnet to strike any surface.  The force can be adjusted with different current and pulsing rate.
The linear motion is not as efficient as circular motion.  The arrangement can be coils in the stationary middle cylinder; a moving magnet on an outer enclosed cylinder.  Magnetic attraction can be used to rotate the magnet.  This arrangement can already lead-out electron motion A.  If we suddenly stop the magnetic attraction, the magnet will tend to fly away due to the centrifugal force.  We can have unbalanced force to provide the propulsion force.
Building the flying saucer is now theoretically possible and the proof-of-concept experiments have been performed.  However, this is likely to be highly classified due to the potential military use.  We may just continue to do the basic research and let the Governments build them.  Rumor says that these have been built in Area 51 in USA and Nanjing in China.  Should we believe rumors?
*** The list of improvements can go on for many more pages.  I shall pause here so that we can continue the other potential interview questions. ***
chrisC
Quote from: ltseung888 on January 17, 2010, 06:04:35 PM
11. What  do you expect to  to the ?
Improvement 15
It's amazing how much delusional crap can one person generate in a couple of days! Even the follower sheep are surely embarrassed by this crap?
cheers
chrisC
chrisC
Quote from: P_M on January 17, 2010, 07:29:10 PM
@ltseung888
in German it says "Dummschwätzer"
two and a half years to  so much, you are nothing and have nothing
haha! The English language is not as advanced as German; we have a simplified word with two syllable and it is called "Dummy"!
cheers
chrisC
ltseung888
Potential Interview Questions
12. Are you willing to work with outside parties to move this technology forward?
Yes.  We worked with at least seven groups before we found Mr. Tong Po Chi who could actually produce an overunity wheel.  We do not mind working with outside parties to move this technology forward.
We are doing that in Hong Kong.  We put the Tong Wheel in the Better Hong Kong Radio Studio so that others can evaluate it independently.  We put much information on the Internet so that the potential participants will be able to have the right expectations.
In short, we have the Lead-Out Energy Theory.  That can be applied to almost all OU inventions.  We have the Tong Po Chi Lead-Out energy Wheel that has been demonstrated to over 25,000 persons.  There is some dispute on the cheap meter readings but they provide a good general direction for improvement.
We listed 15 potential improvements.  We welcome outside parties to work with us on these.  They may be able to think of other improvements.  The research is open to the World.
