Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bob Boyce
I have another longitudinal winding completed, on the top face of the toroid core. My fingers are not as nimble as they used to be. It takes me a long time to do so very little winding by hand. Beeswax is our friend, as it allows windings to adhere to the core as they are wound.
Bob
Thaelin
@ Bob:
   Do you feel it to our advantage to add these for better control of the bias field?
@ Bruce:
   Found my parts in Portland ME!  On the way now, I hope. Should have the controller done before the torrid gets here.
thaelin
Bruce_TPU
Quote from: Thaelin on July 27, 2007, 07:48:29 PM
@ Bob:
@ Bruce:
thaelin
Hi Thaelin,
That is a good question for Bob, and my question also.   ???
@ Bob
Hmmm... That last winding was not placed where I was picturing.   :o
So much for my solenoid analogy with that winding.  LOL
Bruce
Bob Boyce
@ Bob:
thaelin
The intent of face windings is not related to potential or magnetic bias, it is for some experiments I wish to run once I have this unit connected and operating. Note the orientation and direction of this winding in relation to my location. Northern hemisphere, CCW rotation.
Bob
Bob Boyce
Quote from: btentzer on July 27, 2007, 07:54:31 PM
Hi Thaelin,
@ Bob
Bruce
Yea the next one, on the core bottom face, will be harder for me due to the reverse winding direction. I'm so used to winding CCW ;-)
In the past, the flat pancake coils I have wound were typically bifilar and wound in a coil form the width of the wire. This winding on the face of a toroid took more time.
Bob
