Tesla Switch need help
Started by TheOne, September 16, 2007, 07:27:52 PM
NerzhDishual
Nolite mittere margaritas ante porcos.
Groundloop
@allcanadian,
I agree with you 100%. Today I got my batch of NiCads and now my Tesla switch is running on four 9,6 volt 700mA battery packs. The circuit is running fine switching at approx. 20 Hz but I got NO usefull output. Only 2,8 Volt. This was enough to lit a ultrabright LED very dim. So I can say that my circuit as it is now is flawed beyond recognition. I will try to do some modifications but all in all it was wasted time and $845 USD. I think the way to go is as you state with both L and C in a circuit.
Groundloop.
nul-points
@allca. Nerzh & Ground
thanks for comments & info - i'll look up your links ND, too, thanks
yes, the inductances have certainly helped (feedforward Xfr & enabling flyback diode action) but oddly i seem to remember that my very first charge anomaly results were obtained with Cct1 before i included a serial coil with the switched cap
anyway, i can confirm that the 'magical' 50% loss of energy is not happening with these circuits - i've been able to drive 24 mW into a resitive load for a power draw on the input caps of 29mW - a fairly respectable COP of 0.83 (83% efficiency)
i know its not out of the ordinary by commercial PSU standards but not bad for a few simple components stuffed in a breadboard (and my first-ever attempt at designing a switched-mode PSU, apparently!) - way better than the 50% limit insisted on by some heavy-duty dudes writing peer-reviewed papers about cap to cap discharge being a dipole aerial and half the energy being 'I^2 * R losses' or 'radiated away'
most significant for me is the 'Conservation of Charge' issue - What conservation?!?
if charge isn't being conserved (as required by Kirchoff & Maxwell) then maybe Energy isn't quite behaving like these guys claimed either!
something is definitely going on in the Physics Department after all the Professors have gone home for the night
Game On!!
NerzhDishual
Hi Nul-Points
We are on the same page. Sorry for repeating myself, but  did you check this link: http://freenrg.info/Condos/ ?
(This page is not still updated).
Actually, according to very simple experiments, I 'lost' nothing when discharging
a filled cap into an empty one.  That is also:
Quote from: nul-points on March 30, 2008, 05:30:44 PM
.......better than the 50% limit insisted on by some heavy-duty dudes writing peer-reviewed
Is it not?
Best
nul-points
@Nerzh D
same page definitely!
yes, i've just checked your links and that is one cool rig!
you could lose my breadboard setup inside one of those caps!!!
you're right about neither of us having 'lost' in our experiments - but only as far as charge is concerned:
my test started with 2 Coulomb (C) of charge and ended with 2.9C - a 45% charge gain ...BUT...
started with 6 Joules (J) of energy and ended with 3.215J - a 46% energy loss!
and your test started with approx 2.6C and ended with 3.3C - a 27% charge gain ...BUT...
started with 33.8J of energy and ended with 28.4J - a 16% energy loss
so we're both seeing anomalous charge enter our circuit from somewhere but in both our tests we've used up a positive amount of energy in charging the second cap from the first
at the moment, the anomaly which appears to conflict with conventional circuit theory is that both our experiments have violated the "conservation of charge" rule - pretty impressive in my view
...and if that's true, that means that Kirchoff & Maxwell owe us a beer!!   ;)
