Lords of the Ring 2
Started by hartiberlin, September 21, 2007, 09:14:07 AM
ALVARO_CS
hi Magluvin
the file you mention is the video shown in post 27 page 2
cheers
Alvaro
Magluvin
Magluvin
wire,"wire material" :
https://patents.google.com/patent/US4913744A/en
The construction may comprise different photovoltaically operative inorganic and organic materials and may assume various configurations.
https://patents.google.com/patent/US20070246094
Patent citations !
an-organic or organic :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=marcel+meredieu&CPC=&IC=&Submit=Search
material : specific frequency,Eigen-Spin, related : Spintronics
https://www.google.com/search?client=firefox-b-d&q=spintronics+review
f.e. : http://www.rexresearch.com/zaymidor/zajmidor.htm
Professor Naoshi Ikeda ,Okayama Graduate School of Science and Technology
Sincere
OCWL
p.s.:        experimenting ?
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=hanna+albert+awad&IN=&CPC=&IC=&Submit=Search
p.p.s.: https://overunity.com/3344/lords-of-the-ring-2/dlattach/attach/179839/image//
                                           magnetic field = infra-red field
https://fdocuments.net/document/chapter-7-electromagnetic-radiation-aka-radiant-energy-or-light-a.html
  EM RADIATION FIELD -BARRIER  https://atticfoil.com/index.php/about-radiant-barrier/why-is-an-air-space-required/
Mr. "I will be back"( Ex-Mister Universum,body-building) movie and detector :  https://www.youtube.com/watch?v=AAzja2tWAg8
https://www.reflectixinc.com/  https://www.reflectixinc.com/wp-content/uploads/F3-OEM-Guide.pdf    1980` ::) 1880` :)
What is Reflectix®Insulation?
Our standard product is made up of seven layers. Two outer layers of aluminumfoil reflect 97% of radiant heat. Each layer of foil is bonded to a tough layer ofpolyethylene for strength.
Two inner layers of insulating bubbles resist conductive heat flow, while a center layer of polyethylene gives Reflectix®high reliability and strength.Reflective Technology - An Old Concept:In   the   1980's   the   Scottish   chemist   and   physicist   Sir   James   Dewar invented the Thermos flask, also known as the Dewar flask or vacuumflask, for the purpose of storing liquid gases at very low temperatures.
The basic function of the vacuum flask is to thermally insulate the con-tents and to prevent heat from flowing either in or out
Faraday cage comparison !
https://www.reflectixinc.com/wp-content/uploads/f2-solutions-for-the-pro-0809.pdf
page 10
Reduces noise through plenum             THERMALVOLTAGE also called THERMALNOISE ,THERMALSOUND
Paintable  https://en.wikipedia.org/wiki/Infrared , insulation,mirror  :https://www.patentauction.com/patent.php?nb=11044
2007 ! https://overunity.com/3286/zimmer-billig-mit-strom-heizen/
Re: Zimmer billig mit Strom heizen  « Reply #6 on: September 13, 2007, 02:10:57 AM »
https://overunity.com/2606/electricity-saver/
https://wattsupwiththat.com/2010/08/17/survey-says-many-are-still-clueless-on-how-to-save-energy/
About Academies of Sciences quality,trust and faith  :
https://www.greenbuildingadvisor.com/question/why-is-reflective-insulation-still-being-sold-by-hd-and-lowes-and-used-by-many-contractors
Study Electro-Magnetic RADIATION by thermographical camera,by thermoacoustical camera,
                                 both :        Thermical Audio-and Video- camera  8)
Muenchen,ehemals Solln ,Fuerstenackerstr.34,Vermieterin : Frau Ratzinger-Beck
1987
CENSOR : CENSUS INVEST
Denn DEIN ist das Reich und die Kraft ..........
SYSTEMRUECKABWICKLUNG,vor 1987 STANDART
BGB : 30 +3 Jahre Verjaehrungsfrist ORGANISIERTER BETRUG
2020 - 33 = 1987
giantkiller
FE is iron wire.
I had two tests for this. The first one was in parallel with the internal horizontal loops. The second one was FE through the center toroids. Either way they both receive.
I keep repeating that this thing is extremely noisy. It is a huge charge pump/ center of stun gun circuit. And it can be built using Radio shack parts like SM stated.
SM stated that all circuitry must be in the middle of the device. I still laugh at this remark. Of course. Where else would you put the antenna?
In the middle meant both inside the verticals and in the device center. He sure did play with words to get the configuration and protocol exposed.
In the LTPU demo in the hotel room SM swipes a cabinet magnet around the outer side. Mid way he lets go and it sticks! So he showed iron wire and the switching of the battery to resonant power.
Now here is the item that I never saw covered and that was the device never runs a long time. SM mentioned heat build up but he could also have been eluding to entropy.
And no telling if he was pointing out resonance. He did mention be careful of getting the two frequencies close. He did mention the exploding TV so I sincerely believe he knew what he was talking about and capable of.
So in response to Bob Smith's remarks, heterodyning can be a positive or negative factor.
I know in all my tests heterodyning really caused a lot of problems and not that that was bad. I have all new equipment on my bench. LOL.  And after 2 scopes, 2 meters, a truck, 5 neighbor's cable routers and one divorce. Its all fun and games till somebody takes offense of the mystery.
@MasterPlaster: refresh my mind about the heat up. I did post about the neon starters needing to warm up. I have a setup where the outer primary has a neon starter in series. They glow at startup but then after warmup they really chatter. I use that to test the reception of the windings. With what I have now is on that output bridge if you exclude a filter cap the LED lights bright off the peaks of the oscillations where with a cap the LED is dimmer due to just running RMS. ...naturally because the cap diminishes the high spikes. A way better method to test than delicate bench equipment.
If this is not what you meant let me know. And cheap Stun gun oscillators are not meant to run continuously either. I have hemi'd mine up.
