Lords of the Ring 2
Started by hartiberlin, September 21, 2007, 09:14:07 AM
forest
Well....excuse me but as I become older I prefer simpler explanations.So what is the principle , can you explain schematic in parts ? Charge pump and magnetic field collapse into the FE rod do not disturb charge pump ?
Actually I planned to use such method to generate excess heat in shorted FE pipe.I remember there was video from russian fellow about some "magical" transformer being a pipe constructed by glued ferrite rings and secondary being FE nail
giantkiller
When the charge pump finishes building the field crosses the gap between the ring verticals and the center toroid verticals, the discharge trigger enables the charge dump into the FE.
I refer to the previous video post of the field expansion.
I did add a tank circuit below the collector of the q3 and above d3 that matches the oscillator frequency so that the d3 did not discharge the pump.
The harmony of the system starts with the air gap. The drive power sets the timing in the air gap crossover. SM mentioned a frequency of 5k which is coincidently the most stun gun oscillations.
The crossover timing has to agree with the harmonic reflections in the system.
Follow Tesla coil testing with the test equipment by not connecting to device. I use an EM meter and SWR meter. Those fuses in the back are for testing also. I have connected them at places where I though SM would have used the empty tabs on the center toroid box.
The snubber acts like a non destructive spark gap.
The oscillator of the system is an Armstrong oscillator configured as an air core High Q multiplier. This is it in a nutshell.
When everything is hooked up then play with the drive current. Two frequencies can be used to enable the triggering with the heterodyned outcome.
Place a small neodyn on the FE. I use the little ball as it is light and will respond anywhere on the FE.
The magnetic field does not hold well with out drive. It also prefers to remain stable in the event of an in field disruption. The internal spark gap of a stun gun is amplified by the field in the charge pump and the secondary inductance. Telsa goes through extreme measures to get a capacitance in the surrounding field. That way there is no device to breakdown under the high orders of charge held. In the TPU SM gives warnings.
giantkiller
giantkiller
I thought this might open some minds...
giantkiller
https://www.nuenergy.org/nikola-tesla-radiant-energy-system/
QuoteEnergy Directly from the Atom
The radiant energy system is a self-oscillating capacitive system. Once it is set into oscillation, very little power is expended in keeping it going. Because it is an electrostatic oscillating system, only a small amount of charge moves through the system per cycle, that is, the coulomb per seconds = amps are low. If the charge is used at a low rate, the energy stored in the system will be turned into heat at a slow rate enabling the oscillations to continue for a long period of time.Tesla's "COIL FOR ELECTRO MAGNETS," patent #512,340 is a very special coil design because, unlike an ordinary coil made by turning wire on a tube form, this one uses two wires laid next to each other on a form but with the end of the first one connected to the beginning of the second one. In this patent Tesla explains that the double coil will store many times the energy of a conventional coil.[1] Measurements of two coils of the same size and with the same number of turns, one with a single, the other with a bifilar winding, show differences in voltage gain. These bifilar Tesla's coils can be explained solely on the basis of their electrical activity. A bifilar coil is capable of holding more charge than a single wound coil. When operated at resonance, the distributed capacitance of the bifilar coil is able to overcome the counter – electromotive force (e.m.f.) normal to coils, inductive reactance.
Because of the electrical activity, a bifilar coil does not work against itself in the form of a counter – e.m.f., the potential across the coil quickly builds to a high value. The difference between the turns becomes great enough that the energy is practically all potential, at this point, the system becomes an electrostatic oscillator.
Minimal work is done in my radiant energy system due to the absence of wasted displacement currents. As small heat losses occur, oscillations are maintained by surplus charge generated by atomic catalytic reactions, energy is siphoned from the kinetic moments of these charges. Very low energy expenditure allows power delivery to an electrical load over an extended time period without an external fuel supply. After an initial input of energy from an outside source, the radiant energy electrical generator will operate as a very efficient device.
By reviewing history it is understandable why some inventions are not commercialized. It is economics, not science, that is the main factor. It will be remembered that alternating current was opposed by powerful financiers in Tesla's time.
Michael Pupin, noted in his autobiography:
"...captains of industry...who were afraid that they would have to scrap some of their direct current apparatus and the plants for manufacturing it, if the alternating current system received any support. A most un-American attitude...but ignorance and false notions prevailed in the early nineties, because the captains of electrical industries paid small attention to highly trained scientists."[2]
It takes very little energy to promote a resonant field.
The charge pump is the heart of microwave ovens, analog tv, automotive ignition systems. and stun guns. SM even promoted the exploding TV as an accelerating charge pump of vast amounts of energy. The main problem with the exploding T.V. circuit was there were no components in place to dump the collapsing field to ground. Sm stated 'There can be no ground in the TPU.'
I promoted setting a charge pump of a 20 foot diameter next to an airport. He emphatically stated 'No'. I got his attention.
Application of the High Q multiplier circuit merged with the charge pump circuit is the TPU schematic yet no one tries this.
The field in the charge pump(the large vertical windings) builds and crosses the space to the center toroid triggering a field collapse into the middle FE loop. This creates a one way magnetic diode. Does anyone catch this? The original promotion was '90 degree coupling'.
I am the only one who has spent years showing the subsections of this circuit without conjecture from the greats, Ion, Marco, SM, Erfinder and the others that left immediately after I exposed the charge pump as an integral part of the device. The last statement made to me by Moab was 'Put a diode in it!'. Configuration proof.
I even built the large TPU in accordance with what we have seen and proved the configuration works as a charge pump replicating the field size and strength promoted in the exploding TV. I even EMPd 5 cable routers throughout the last neighborhood I lived in. More proof. The energy is there.
Final answer is and for the new members that are eager the schematics are in my previous posts across OverUnityResearch and OverUnity. They are out of sequence.
Exact copy of TPU is the LTPU build using twin lead outer wrapping. The device is staring everyone right in the face. Build that model with the large vertical air core as part of the charge pump and one will see the field strength meter show the energy. What is the final standalone device? You will see it when you start blowing shat up. The largest TPU is the Alcubierre device. Another example in our faces. Yet people want destructive propulsive detonations or free demos.
I know there are watchers that want the final answer handed them so they can self promote themselves into history. Marco warned me about this and now I have to watch this action unfold.
I am not into this for followers or fame. From the smallest to the largest devices there are many examples of the technology out there so one can not really be the hero.
It is the High Q multiplier circuit merged with a charge pump, i.e. the exploding T.V.
There it is, schematics and demonstrations. The trolls, weasels and prairie dogs finally have what they have been searching for...
