Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
giantkiller
Quote from: giantkiller on May 29, 2008, 11:53:29 AM
The points that I show and the leads to read are actually more productive than spoon feeding pablum. Less questions and faster mind travel.
If you wind the coils on those soon to be empty rat shack spools then the air gap exists in the spool. ;D
The 382282 is in quarters. The gke2lego_pmh is in halves. But when I add the iron segments then I get quarters, kinda. I am still continuing with the NT382282 build. Work smart and produce more. And if this should not be the last step, the results from this build have been the best so far from any thing I have seen. The other builds all lead up to danger. So far this has been just equipment loss. ;)
Dont rush. What you are working on now does produce great artifact. I have not seen these waves before. And they are Jahweh phat!
For all the Christian readers I repeat this. Ask once and receive a thousand fold. It is in this last wave. I pulse in 31khz and get 5mhz!  It ramps up. There it is on the scope shot. 'I ring the Bell' exclaims Quasimoto.8) But it grows!
And in regards to the previous post about Gnaural2. Go get it. The brain loves sound. This program heterodynes in your mind!
You want be to happy? Pick a freq. You want to be productive? Pick a freq. You want to produce? Pick a freq. You want to get high? Pick a freq.
Doggy treats for the brain. Avoid the noise.
I am back on the bench tonight. I will raise the 31khz up to 40khz - 50khz. I added coils and did not adjust the input parameters. And put fets in parallel.
I will also try a monostable to see how far the ringing extends to.
--giantkiller. If yer not having fun you're just sluggin' along.
bhaas
Well I got started when i got home from work. Was winding my core coil
on a 5" dia CD container but didn't notice at first that it had a slight taper
after an hour of fighting that I went to a 5" dia piece of PVC I had. Much
better but hard as hell to get off. I wound that tight.
The wire I got sucks. It's wound on a flat piece of plastic so it has kinks in
it. So now I have kinky cores  ;D Both look good, the second one I did is
fatter which is what I wanted.
My hands are killing me from straightening out that wire. Ain't buying that stuff
anymore. I hope. Don't know if I have the heart to cut the one I just finished in
half. But I probably will. Got 2 3/4" neo mags to put in there and they are strong
to. I got a scar to prove it. Damn things come together pretty quick. Also ordered
that FreqGen since my e-Bay one is crap. Got some variacs to play with to. I
think that's what they're called? Glorified switches?
This is gonna be a fun one  ;D
Brad
casman1969
Hey GK,
Have'nt seen any updates lately and just wondered if you are doing O.K. or did you get sucked into the Aether?????
Anyway I truly hope all is well and that you are continuing the quest.
This is one of the most interesting threads here so plz update progress.
A fan,
Carl
ps
I found that you are right concerning the hollow core as a driver but as a pickup it works GREAT!
casman1969
oops!
last ps was to be directed at Honk...
sorry
Carl
giantkiller
Quote from: casman1969 on June 03, 2008, 12:34:05 PM
Hey GK,
A fan,
Carl
ps
Time to wake up!
With the air gap I reached resonant rise. The spike occcurs right after that when, and I mean the pulse circuit goes positive which takes control of the field vectors. The alignment then reports on the scope as we are all used to seeing it. A high pulse. When the pulse goes off the magnetorestriction then takes effect and the circuit rings with external energy. Its like an array tuning forks.  We hit one and the others chime in.
Choke on this. If, whoever reads this does any build at all, this is the one. The mechanical combinations and circuit explainations are all here. This has gone on long enough and now I drop the answer here. I have posted the easy way to build this. An iron bundle with a 26awg rat shack spool. Just like SM said! Off the shelf.Too many other explainations have followed.
http://www.intalek.com/Papers/Handout3.pdf
Look at the pictures and you will just sh!t yourself. There should be no more questions or any follow on theories. I have done the simple tests. Now I go down in history with a few others that have experienced magnetoresistriction
Oddly enough the document has all the categories ever mentioned here in OU.
The recipe is in the size of the mass, the placement of the airgap, how to drive it, and how the read it. It has all been done before very simply./b]
This is a very good avenue to go down. ;)
I uploaded the clearer picture. Read the values.
http://www.overunity.com/index.php?action=tpmod;dl=get82
I greatly applaud GK's success.  But I think the main reason WE as a group haven't achieved success is because we have lost our focus.  If we re-read the 13 PAGE ATTACHED FILE (MS Word format) containing SM's words & admonitions ( and watch his videos), he mentions 3 Control Windings over the Collector Winding to cause a Rotating Magnetic Field.  Remember that he uses the analogy of  a GRADUAL "revving up" (or down) like a turbine.  He says we can SEE IT on a compass placed in the center.  Remember, SM said that modern MICRO CONTROLLERS make things easier.  Hmmmmmmmm, why did he mention Programmable Micro Controllers?  Let's see.
So far, most of us have been focusing on 3 different Frequencies,  BUT, how can 3 frequencies, feeding 3 Control Windings, NOT SYNCHED TOGETHER, cause a Rotating Field.  The answer is they CANNOT.  How can they?  When Freq 1 is rising on the scope, Freq 2 might be falling, & Freq 3 might be at zero.  This is feeding continuously conflicting data to the Coils.  No, this will not do it my friends.  Unless we can rotate the field in synchronization (to Rev it Up), we cannot achieve success.
Plus, why build 3 Levels all at once.  Why not build 1 Collector Coil Level with the 3 Control Windings on it to test our circuit with a compass.  One level, rather than 3 will at least tell us if we are on the right track.  Levels 2 & 3 can be added later after success with Level 1.
The objective is to Fire a Pulse to Coil 1, followed by a Pulse to Coil 2, followed by Pulsing Coil 3, etc, etc, etc, around & around in sync.  How can this be best accomplished?  I know there are many ways, such as Crystal Controlled Oscillators, Phase locked Loop Circuits, & Micro Controllers.  But I can immediately think of 2 ways that would be the easiest using 555 Timers.  There are hundreds of schematics on the web for Oscillators, 1 Shots, & Delay Circuits that use 555 Timers.
METHOD 1:    How about a Circuit that has four 555 Timers fed from at least 12 Volts.  Timer 1 would be the Main Variable Oscillator to adjust the Main Freq.  This Timer could feed 3 other 555 Timers configured as One Shots simultaneously in synchronization.  The three 555 One Shot Delay Pulse Widths would be configured to output 3 different Pulse Widths IN SYNC!!!  This configuration must cause each Coil to be Pulsed SEQUENTIALLY, 1,2,3, around & around & around, in a circle!!!
METHOD 2:   Method two is using a Shift Register.  One 555 Variable Square Wave Oscillator would feed a Shift Register that would sequentially fire Power Transistors that Fire the 3 Coils.
I don't no what to say... ???
--giantkiller. Google all the names.
