TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
BEP
@Tao
Answering your questions - My comments in blue:
Where did you source your iron rods from, are they pure iron?
They are from bundles of marking flags sold in a hardware store. The diameter is a little over 2mm. They are somewhat stiff but brittle. I am sure they are just a very low quality steel. The bundle length is about 15 inches an diameter about 1.2 inches (fits in the spool center)
Am I to take it that you feedback power through your simple oscillator and your 2n3055 blew? Or did it blow simply because of too much driving power? :)
In this case I'm sure it blew because of overdrive or flyback. Base bias was just a variable resistor from the collector pin. PS current stayed under 1A. Voltage applied was 3.5DC. Collector coil is a 800ft. spool of 22ga. magnet wire. Feedback coil is a 1200ft. spool of 24ga. magnet wire. The 22ga. coil was between the collector pin and B+. The 24ga. coil is between B- and a capacitor (.1mfd) the cap is then connected to the transitor base.  A dirt simple 'blow me up circuit'
How strong were those 1 Hz thumps? Just wondering...
The bundle has some weight to it. Movement was axial and radial. Axial movement was enough to feel with fingers. Radial movement would have broken sheet glass from a common window.
I must say, the parametric array, and even more so, a simple ring formed of iron wire with driving coil(s) around it, driving a lower frequency 'longitudinal' 'sound/vibration' through the iron ring and at key successive moments when the LAST sound/vibration made its way back to its starting point, another was generated/driven into the iron so that these longitudinal sounds/vibrations ADDED, certainly would seem to related directly to our old friend the Hungarian: http://www.overunity.com/index.php/topic,3068.0.html
Yes. The Hungarian again. I have no doubt his work can explain most of this - if not all.
Bruce_TPU
@ Duff,
I have been unable to find the following two statements in either of my .PDF's or noted.  I would like to know your source for them please:  You attribute them to SM.
2. It may be relevant to convey the importance of the relationship between the resonances/wire lengths of the control/collector coils. I think of it a rotational magnetic reciever. Some of the tests that I have carried on the coils that have visible control windings indicate frequencies in the megahertz range
AND
9. We are Searching for a rotational Kicking field that can be accelerated by applying harmonics.
Thanks,
Bruce
BEP
Kicks from a vacuum tube?
I don't know what any books say as the ones referenced were not found by me but think about this:
A simple rectifier (get those dirty little SS thoughts out of your mind - TUBES) Even more simple than most would think of - I'm saying 'hot cathode'. That means the heater element is the only cathode - no metal sheath around it - no separate connection for the cathode. The only two elements in the tube are the plate and the heater.
Heater elements were made of many different things but most would be excellent magnetostrictive metals. And guess what? Like GK says 'the light is a residual effect' and so is the heat. The first thing that happens when you apply current to the heater is it has a sudden increase in length - then it glows. What about the required magnetic field you say? It is a current carrying wire - and the tube is a mini particle accelerator. What else do you want?
How does the heater voltage appear on the plate signal? Because the heater was AC. Hot cathode tubes were nasty amplifiers until some tricky LC heater circuits were done AND the separate cathode was introduced. The alternating heater current would modulate the plate signal ââ,¬â€œ and sometimes create a feedback loop, a great source of harmonics.
Anybody with some age has experienced this kick. Scopes are one-eyed monsters. Donââ,¬â,,¢t let then ââ,¬Ëœnarrow YOUR bandwidthââ,¬â,,¢. You old folks remember the ââ,¬ËœWUMPFââ,¬â,,¢ sound when you turned on the old tube radio? The heaters were not lit at that point!
How about now when youââ,¬â,,¢re driving and some idiot has his stereo too loud? All you hear is ââ,¬ËœTHUMP-THUMPââ,¬Â¦THUMP-THUMPââ,¬â,,¢. And when the fool cracks his window the thumping noise goes away but you notice it wasnââ,¬â,,¢t the same rhythm of his music.
If it gets hot - SO WHAT? Heat is energy. I'll make use of it.
Bash the inventor - Already been done - wasting forum space IS MY JOB!
Only searching for the truth? Good - so am I.
Witholding information for personal gain sucks. Witholding information to prevent harm is bad enough.
No, Bruce. I'm thinking of something else.
Enough. I'll take a pill and go back to the bench.
devilzangel
Quote from: BEP on October 06, 2007, 12:55:38 PM
Hey BEP .. if the point is to use heat energy, there are plenty of other much efficient methods of harnessing heat energy mate.
the fact is, the byproduct of a "functioning" TPU, heat, is BAD for any operating generation device. It acts like a built in timer for the eventual degradation of the generator. JUST like all other devices that get heated in operation.
do you think CPU manufacturers really like having heat? I hope not.  :o
*** To everyone:
stop with all the preconceptions everyone!! Just bc SM made a TPU with heat as a byproduct doesn't mean a highly evolved TPU technology will also have heat; it is NOT a necessity.
Dont tell me people here have tried every material under the sun to try to make this device; all i have seen are failed attempts to copy/replicate what SM implies/says are the materials for construction. No one here has the right to say "you must use this material". Even if you are a great grandson of Tesla.  ;D
either SM is a very very poor explainer; or he is very very good at misleading. So think OUTSIDE the box!!!!  :o
in the end all of us here all trying to free ourselves from the people who want to suppress humanity. 8)
devilzangel
BEP
I'm not implying that heat is required for the function.
If it is going to happen - I'll just make use of it.
