TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
0 Members and 18 Guests are viewing this topic.
z_p_e
Quote from: acerzw on October 08, 2007, 03:47:31 PM
A fan will not help as SM stated, the heat can be radiated away, but the heat is caused by mechanical stresses in the coil, presumably due to its expansion and retraction because of magnetorestriction, which degrade its material over time.
Magnetostriction does not occur in the coil, and this is not what causes the heating. Read SM's material.
A single TPU cannot run for a prolonged period of time because of the degradation of the coil material, of which the heat is a by-product. Removing the heat with any form of cooling device will not make a TPU reliable, the heat does not cause the damage, the heat is a result of the damage being caused.
The heat problem is caused by eddy currents. Read SM's material.
This demonstrates the first fundamental flaw in the TPU's design, because of the mechanical effect that it utilises, it has an unavoidable mechanical mode of failure, despite being 'solid state'. It just flexes rather than rotates, in effect it is a linear motor and will eventually fail like one.
The mechanical effect may only be a by-product of the conversion process. There is no iron in the TPU aside from the ferrite cores, so magnetostriction is unlikely the cause.
What comes out of this group will not be covered by any TPU patents if they exist, because in essence it cannot and will not be a TPU!  8)
What is a TPU? What would preclude a successful working device here from being the true TPU?
@tao, your idea is clearly insane, if you do not desire the TPU to be portable why bother working on it! There are many other much more efficient and reliable mechanical OU devices (and yes a TPU is mechanical for the reasons given above) which can serve the same purpose as a non-portable TPU for instance:
You're basing this statement on the assumption the TPU operates using magnetostricition, AND that the coils degrade due to mechanical stresses. If the TPU does not operate using MS, (and imo it does not) and there are no mechanical stresses on the coils (imo there are none), then tao's proposed solution is 100% plausible.
I encourage you to re-read SM's material. Clearly the essence of his messages are becoming clouded here, and the facts messed up.
Oh, and btw, as far as I know, SM never ever mentioned the word "Schumann" in either his material or videos. You inferred that he did.
MACEDONIA CD
hi EMDIVICES  AND TO ALL
  how are you my friend  ..   i have  great progres  whit  this theory////  i make  in this  in practical  is forking   .. if you read this  you know what im tell you  ...and now  i have tell you  to all  i made some  whit thiny wire  is like a magic things  <<< you imagen  what  whill done whit  many wire   >>and simple  push of litle  energy  just  is  need 5 or 6 second  to start  then  is hapend   the kick then this kick  is created  my god is fantastic thing  of increse  the power of out
-0000000000000-00000000000000-000000000000000
  TO ALL  i whant to ask  something <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< what you mean  is posible  whit simple  1 kick  to make  5000 kick  in 1 single second  only whit  small batery  or perm. magnet   i have find  the ansver  and  i made some of that  ..you nnow what i m say  my friend  EM.  i hope to reply
MACEDONIA CD
ONE  HELP TO ALL  you every one is look the tpu  whit  2 bulb  when is start whit 2 perm magn.  ok
in one of the ring SM is put 4 coil and find the ansver   ;) ;) ;)
acerzw
@Macedonia
It sounds like you have had some success, can you do a drawing for us? Difficult to understand what you mean..
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
wattsup
Question. Why is an alternating current of 6000 hertz considered DC?
