TPU - General Discussion
Started by z_p_e, October 01, 2007, 11:32:43 PM
Earl
Quote from: wattsup on September 20, 2007, 04:13:49 PM
Hello Mac, (short for Macedonia)
I am sorry if I am slow to understand what you are saying, so please let me ask you to be more precise.
Are you saying;
[snip]
Now I know you have the answer to starting the current flow with your coil and Buzz11 diode system, as I had indirectly eluded to this when I said pulse the current from the inducutors at 120k, into a cap, but I would like to know where you can get enough power to run an RF Generator and what this will do in the system.
@wattsup
A low-power osc could easily be powered by a 9V block battery.  Only few mA are necessary since the oscillator is only serving as a catalyst.
I had thought that the great inspectors that have looked at SM's devices had checked for any RF or other wave or signal emmanations and I do not remember any of them saying this to be so.
The TPU documentation clearly shows that the TPU was putting out a lot of RF hash and would interfere with correct operation of power converters if it got too close.
And why are you talking about the atom bomb?
MAC is talking about an uncontrollable energy avalanche.
And why are you saying SM is like Tesla. Tesla brought his products and inventions to the world, openly patented them and we use them today. SM hid his device from the world and we are not using them today. There is a very big difference. I am sure if Tesla was alive today, with the communication as it is, he would be on the internet explaining every little aspect of his systems, his knowledge, etc., and we would not have to play guessing games until the moon turns blue. I don't think you can put them on the same stage.
Negative.  You are suffering from self-delusional hero worship.  Tesla took the secrets of his electric Pierce-Arrow with him to the grave.  SM and Tesla are maybe identical twins, if the TPU is not a fake.  As much as Tesla is my idol, he was not only extremely intelligent and very ecentric, but also a chicken shit.  Yes I know, the truth hurts.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
EMdevices
Here's an interesting paragraph:
Composite Materials
Ã,  While Terfenol-D and other magnetostrictive materials are potentially important as actuator materials, some limitations have limited their adoption over more traditional piezoelectric and electrostrictive materials.Ã,  The two most important issuesÃ,  are eddy current losses due to high frequency operation, and poor durability.Ã,  Due to the time changing magnetic field used to actuate Terfenol-D, eddy currents are developed within the actuator material itself and hamper its use at frequencies above 2 kHz.Ã,  Polymer matrix composites, using a particulate form of the magnetostrictive material, essentially eliminate eddy current losses to 100 kHz and beyond.Ã,  Furthermore, the polymer matrix used to bind the particulate produces a relatively tough material that can better accommodate tensile and shear loading states.Ã,  Hoping to take advantage of these benefits, research into magnetostrictive composite materials has been performed at UCLA since 1994.Ã,
Ã,
Eddy current losses?Ã,   Yes !!
Reserach at UCLA, in SM's backyard, since 1994?Ã, Ã,  Wow !!
@ BEP
It's true about the magnet doing the same as DC bias, but in a ring how do you use it Longitudinally ?Ã,  Ã,  :)Ã,  Ã,  I'm seeing a DC bias coil now in the Open TPUÃ,  LOLÃ,  (it's the fat red coil under his right hand)Ã,  :)
EM
P.S.Ã,  By the way, Terfenol-D is one of the best magnetorestrictive alloy, but pricey $$$$
REF:  http://aml.seas.ucla.edu/research/areas/magnetostrictive/overview.htm
Earl
@ALL
Here is an idea for a simple quick and dirty quadrature oscillator.
Important are identical coils and careful and symmetrical constuction.
The inverters could be 74HC or CMOS or TTL or LS or S or RTL or tubes.
Pick your poison.  I suggest 74HC inverters, maybe Schmit-trigger input??
With CMOS inverters, it may be desirable to insert series resistor on output
gate feeding coil to quasi form a current output instead of a voltage output.
If the frequency bandwidth is sufficient, the best inverter would be the old
HEF4007B from Philips / NXP.  It has access to the sources of both the
N and P channel FETs and it is possible to insert resistors in each source
thereby turning the output stage into high-impedance constant current output
instead of low-impedance voltage output.  When feeding inductance, this
tends to give sine waves instead of square waves.
360 / 4 coils = 90 degrees = automatic rotating field
@BEP, thanks for the great drawing
Regards, Earl
Grumpy
Bridges breaking and lightning strikes are not the same.  SM used the term "explosion" - that implies a sudden surge not a slow buildup
You will not get a "lightning strike" with megnetostriction.
I have used Terfenol-D in actuators (for an electro-mechanical switching device) - if this was used the the TPU would not be "cheap" to build.  You can get sample kits of this material - or at lest you used to be able to.
To get a lightning strike - you got to screw with the "potential"  ;)
        -Frank Edwards
BEP
@Earl
You're welcome.
There are a couple of things I'm sure of.
1. The dimensions are fairly close
2. The four coils are not all wound in the same direction (see photos)
3. There are a total of six coils not counting possible coils in the two legs.
Possible:
1. There is a slit at each quadrant allowing more flex
2. The two 'possible' slits I see are not aligned indicating a possible intended phase shift in mechanical movement
3. Waves of magnetostrictive movement can follow standard wave functions - like interference, summation, cancellation, harmonics, FFT, etc.
At least #3 is the only way I can explain why I pump high freeks in and it buzzes below 60Hz.
