DISSOCIATING WATER, A KEELY Project
Started by hansvonlieven, October 03, 2007, 02:04:46 AM
Cat_Tinka
Hello ! i just like to add what i found from Mr.Andrija Puharich
This device has an output consisting of an audio frequency (range 20 to 200 Hz) amplitude modulation of a carrier wave (range 200 Hz to 100,000 Hz). The impedance of this output signal is continuously being matched to the load which is the second component, the thermodynamic device. (the cell)
The second factor which helps to hold the resonant resonant frequency at 600 Hz is the gap distance of Y, between the centre electrode, and the ring electrode of the cell.
This gap distance will vary depending on the size scale of the cell, but again the current flow, I, is used to set it to the optimal distance when the voltage reads between 2.30 (rms) volts, at resonance Fo, and at molal concentration, 0.1540. The molal concentration of the water is thus seen to represent the electric term of the water molecule and hence its conductivity.
us patent ;  US3563246[1] ,and US3629521[1] ,and US3629521[1]
Good Luck from John  !!!!!
Cat_Tinka
here is the
link to; andrija puharich and water decomposition by AC electrolyses
http://rexresearch.com/puharich/1puhar.htm
with more indepth description
i think this is the secret disclosure worth the effort, to test.
puharich was allso a good friend of Stan Meyer
the above mention us-patents was used for medicine/hearing-aid system/blood systems etc.
but who cares if the same tools can be used for low current water splitting
this is John
fritz
The Synthesis:
If you split up water molecules by excessive torsion waves -
the problem on almost any setup I?ve seen so far is that the
splitted molecules change the density of the water exact in that
area where it happened - means the ability of further splitting
immediatly decreases.
Some patents work with pulse trains and guided, controlled or open
loop breaks or whatever, other ones match and track the impedance,
Keely uses similar with acoustic feedback.
Personally, I think that you can split up water molecules with almost
any frequency - if you achieve a critical stress momentum (by the resulting
wave motion).
The major problem is how to maintain this splitting up process - eg
how to transport/remove the gas without disturbing the splitting process.
rgds.
Cat_Tinka
i found a new link adress
that maybe can be of interest
here.......:  http://www.wasserauto.de/html/more_cars_.html
,i could not open it, can you ?
-it says..........................;
Hallo, Water Cracking Researchers
According to Andreas Hecht from bos-list@sax.de you should have a look to "Experiment zur Hochfrequenz-Analyse von Wasser"
http://buerger.metropolis.de/drax22/
this is a so interesting theme, that i can bearly find the calmness to go to bed...
i paste some more lines from the abovementioned website:
From "FUEL FROM WATER, Energy Independence with Hydrogen" Author Michael A.Peavey Publisher Merit, Inc., P.O. Box 694 Louisville,
KY 40205 Library of Congress Number 88-188956 ISBN 0-945516-04-5, page 22: " The smallest amount of energy needed to electrolyse one mole of water is 65.3 Wh at 25 degrees Celcius (77 degress F). When the Hydrogen and Oxygen are recombined into water during combustion 79.3 Wh of energy is released. 14 Wh more energy is released in burning Hydrogen and Oxygen than is required to split water. This excess must be absorbed from the surrounding media(environment) in the form of heat during electolysis."
And then, "At 25 degrees celcius, for voltages of 1.23 to 1.47 V, the electrolysis reaction ABSORBS HEAT. At over 1.47 V at 25 degrees celcius, the reaction gives off heat."
this sounds fantastic, !!!!
dissociating water must be the smartest ,and maybe the easiest way to provide heat and fuel
and it seems to be ;not verry expencive either.
,i am really looking forward to replicate such a setup,
i,ve got a HGH 500E , but so far i've not dared to test it, it should produce abt 500ml/H/min. at 220v/180W
,i was thinking of adding it into a combustionengine,someday........
so thanks to internett for all knowledge that one can pick up here and there.
this is John ...............(have to smoke outside!!!!).
raburgeson
Hans,
does all the notes have to have the same power DB gain wise? If so the high notes will require one powerful amplifier to produce those high notes. What type of a system will you use for it? These old time inventors really whacked things with power. Every time I touch a pre Einstein circuit I'm faced with the Tesla syndrome. That might be what you are looking at here.
