edork
Hi All
Hey Stifler not take site down they remove you log in - now very simple yes?
Perraultium
Quote from: BEP on October 17, 2007, 01:45:38 PM
My definition of cold electricity:
It is when your 10 Watt 1 ohm resistor, wired in series to the test circuit gets noticeably cooler than it should be. You freak out and check it with your IR thermometer and it shows much cooler than the bench area - even though it has been setting there all day and it is carrying current. Then you give up and have a cool one to clean the wild thoughts from your head. (Notice I didn't say 'another cool one'.)
After clarity arrives you decide to keep it to yourself because you are still bruised from the last time you made something like that public for replication.
Just my opinion.
Why do you make these posts? You don't answer the question what OU device you have created? You make claims of being experienced but never back them up. Post your cold electricity circuit and I will validate whether it works or not.
Your egocentric need for attention does not serve a useful purpose here. You claim to be from Berlin but seem to use American slang and write like an American.
Now either put up, or shut up mister been there done that.
When life hands you lemons, make Perraultium - The high energy element made from a lemon with two probes shoved into it.
BEP
@Perraultium
'from Berlin'? I don't recall typing that.
Hmmm.... it seems only certain folks are allowed opinion here. Very well. I think I'll create an alias for myself and argue with myself for a while. That should be more productive than picking someones work apart without building it first.
It is obvious you want action. That type of action is best not posted here. Neither is a continuation of this conversation.
Freenrg4me
@ EDORK
Hi - Maybe one more post - He did take down some parts of the site. There was a part about an experiment where he was using his transformer to do electrolysis that was interesting.
He was hanging it out there as people tend to be critical of him and he had nothing to gain. I don't blame him for not wanting to hear from people. He sure does seem like an intelligent and nice person that I could learn a lot from.
What? No comment on the fundamental difference between the Meyer and Stiffler circuit? Compression vs decompression?
Cap, inductor, inductor verses inductor, inductor, cap? I really think the compression aspect of the circuit is something that is overlooked. But then I don't know jack about RF.
BIG OLD EDIT HERE
Hey - his BeFe core electrolyzer circuit is still there. I was wrong. He take down his papers for sale which is a bummer cause I wanted to but them and he did take down the ability to send hi a message.
Which I suppose is a message.
fritz
Quote from: jonesbeene on October 17, 2007, 12:45:18 PM
If this type of circuit really does involve so-called "cold electricity" then why would you Fritz (Wolfgang), or anyone else expect a "conventional" meter or scope to give an accurate representation of what is happening?
Of course, even if cold electricity does not exist, the idea of a SigGen heating a resistor to such a degree is laughable.
Jones
Well - what goes in must come out and vice versa -
if everything is shielded and nothing degrades during
operation ..... if not - we have a strange effect - if there
is more useable output than input we have overunity.
Using the temperature (generated heat) at termination
resistors is a typical method of measuring rf rms power.
Especially if the frequencies are very high.
The thermal output gives an exact measure for the rms
power involved. I think the equipement used for that is
called calorimeter (!?) not sure.
If a resistor gets hotter than calculated for the maximum
passive load - the unexpected heating gives the evidence
that the generator operates agains an active circuit or against
a back voltage - could be AC or DC.
This gives you a quite short and easy proof - without changing
the original wiring - because everything you connect might operate
as antenna and may emit em radiation.
So measuring the temperature of a resistor is a quite clever rf
measuring technique.
regards,
             Fritz (thank you for pointing out that I  had some nick
                      inconsistence)
