EMdevices
hartiberlin
Loki67671
All,
I have now gathered everthing but the SIDAC. I managed to get my hands on a spool of the LITZ wire also so fooling with the AM loops is no longer an issue. I'm building my SEC on single sided solder pad prototype board. I don't have unlimited time so my progress isn't very fast but I'm steady moving forward. I hope to start getting some preliminary measurements this week and fool around with the tuning of the oscillator. It should prove interesting. My spectrum analyzer has some dried out electrolytics it would appear. The drift drives me crazy but I will fix that shortly also. I am assured that the view will be very interesting. Next in the project plan will be the calorimeter to measure output power. The input power I will attempt to measure using a high speed digital scope and a current probe. Once this has been accomplished and the results look good I will move the device into the lab, where all of the calibrated equipment resides and see if I can validate Dr. Stifflers circuit performance. More to come......Stay tuned boys and girls.......... :-*
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
Loki67671
Two SEC secondaries wound on paper cores. The one sitting on the back of proto board is wound with cotton covered 10 strand LITZ with individual strands definitely finer than a human hair. The lower is wound from 3 strand Twistite LITZ. On the right is the copper pipe that will be used to excite the LITZ inductors just as Dr. Stiffler has shown in video 9.75 I believe. On to the board layout and soldering of the components into the PCB. The calorimeter will be built in a plastic cooler filled with solid blue foam insulation. Two PMC tubes will be installed, one for delta-temp on the resistor and another to monitor the calorimeter itself, and instead of lab thermometers K-type thermocouples and two DAQ's will be connected to a PC. I'd love to do this full time but that's not going to happen anytime soon.........Jim
DrStiffler
Quote from: Loki67671 on February 08, 2008, 06:54:08 PM
All,
Need to get that analyzer repaired as you will be excited with what you see.
I have included a couple of images, the first is when the Exciter is OFF and the second is with it ON. What is interesting is the Exciter outputs energy from 520khz to 110Mhz, the second is only a small view with the scale of 5Mhz per/div. I marked some of the frequencies and if you look ad my web site you will see that even with the new coil arrangement that the base point are the same.
All things are possible but some are impractical.
