0 Members and 103 Guests are viewing this topic.
alan
@powercat
Thanks for the link, should be helpful.
(lol @ your avatar)
@drstiffler
Need to find out if torque decreases or stays equal if rpm decreases, as a cause of loading.
Quite informative for those unfamiliar with the concept, like me:
http://en.wikipedia.org/wiki/Torque
@aluka
I'd say, current is induced in the cable by the EM field created by the ball.
DrStiffler
@All
Those that have a running exciter that was used in the last examples (chained AV Plugs with Neon) can look at two additional tests if you have the required equipment.
1) This test only requires a change in how the chain is built. My example and I believe those that replicated it, coupled between the chains from the Cathodes of each preceding Plug. To add additional stability and reduce sensitivity to external capacity, alternate from Cathode and Anode. SO from the first Plug couple from the Cathode then from this Plug couple to the next from the Anode. There should be no major difference in tuning or input, but stability should be added.
2) This requires two (identical) current meters and a couple 8V or a 12v and a 6v in series. You want a voltage of around 16-18v, (24 will be to much). Place one meter in the + leg from the batteries and the second in the - leg. Make sure nothing is connected to the Al backing plate on the proto-board. Tune you circuit for max LED output and let it run for a couple minutes. You should see a current of 38-48mA. *NOTE both meters should read the same, if not be sure nothing is touching or connected to the backing plate.
Now when the unit is tuned and both meters read the same, connect an (Earth) ground to the Al (backing) plate. So what do your meters read???
Those that can do this please do and report the results. (Yes) you can do this with a grid power supply, but far to many variables enter into the result. Use the battery approach.
All things are possible but some are impractical.
amigo
I know this might not be exactly on topic, but I had to show how mesmerizing this NE2 glow is - both electrodes are lit up pretty bright using just four small LMD analog networks (2x10mH + 2x0.0056uF each, based on Eric Dollard's research) driven from a square wave source at about 92KHz giving me at the other end ~200Vpp sine wave that lights the NE2 all the way. :)
OK, back to SEC now...
aluka
@ Alan
Thats what I thought first too, Alan but there is only ONE cable not two...and... the electromagnetic field meter shows 0.80NT ( that is ambiance magnetic field). The setup was simple but look at the attached Photo...it is astonishing what this little Battery driven plasma ball is capable off... do you really think this is done from one turn one cable induction?.... :)...
My goal is to feed the little ball with it`s own energy output.....i know 2nd law....maxwell.... but think about vortex tubes, they are a violation too...and i think Dr. Stifflers work is the key.
ramset
DR STIFFLER an AMAZING   amount of talent  and Ideas you have around you here  can we order today ?  thanks Chet
Thanks Grandma
