nickle989
@ Charlie V ...
I like some of your thinking ... start a new thread and I will post some more thoughts on it from what I have seen ... as I agree with the Dr.  .. it took me forever to wade through the whole thread to come to this point.   It would take someone else time and could confuse them.
@ the DR .... could you publish the spec on the coil ? .. if you already have sorry ... my brain is leaking more then it should be.  Thanks.
DrStiffler
Quote from: nickle989 on April 10, 2008, 07:02:00 PM
@ Charlie V ...
@nickle989
See http://67.76.235.52/DrStiffler/coils.htm
All things are possible but some are impractical.
nickle989
@ Dr. Stiffler .. thank you ... the ferite core is it hollow down the centre or just at the top for the adjustment? ... I have seen some that are hollow is the reason I ask. Thanks
@Group ... I broke down and pickup a plasma globe (still trying to get my SEC going) ... found the same results that Aluka was seeing .. the scope was reading a Square 20kHz wave.  I was even getting a very dim lit led almost a foot away on the board with the SEC diode arangement.  As I touch the led it would light up brighter.
Loki67671
@All,
It should be another interesting weekend. Since I don't have my new neon bulbs to melt down I'll have to try this critter. So on the list for Sat/Sun is the little alternator experiment, the alternating cathode / anode chained AV plug connections, and IF I can get my hands on a couple of, 8VDC or so, batteries the floating Al plate VS the earth grounded plate experiment. I am interested to see if a couple of Fluke DMM's have similar enough impedances to execute this test with. Of course I also want to see Dr. Stiffler's point too. Here are some shots of the final assembly of a little 3 phase alternator. Next I will add a PC board on the back of the alternator to terminate each of the six stator windings. I'm going to install .100 dual row header so I can configure and reconfigure the winding topology. I wonder if AV plugs will work here? Hmmmm? Needless to say I won't get much rest this weekend.  ;D I wonder what will happen if...... ;)  8) 8)
Best regards,
Jim
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
plengo
I finally got my orders from Jameco including the Forms, new neons and inductors more in line with Dr's specs. Weekend is almost here and more free time at hand to comence experiments again.
Today by sheer conincidence when I turned on my SEC there was an LED on the table laying there that by sheer luck touched a combination of chokes and the back plate of the board where SEC is running and the LED was lit, very interesting.
And yesterday while running SEC there was another board with many LEDS and AV plugs connected. That second board was totally separated from SEC and it was about 1 feet away, but as soons as SEC would run the LEDS on the other board would light up too, very strange. Almost like transmission of power throwgh the air.
I wish I had a camera at that second to record it. I will try to replicate it again.
Fausto.
