DrStiffler
@amigo
Forgot to add, the reason the LED brightness falls is the LEDS have changed the resonate point of the coils, you have to retune to the max point again. If in tuning your oscillator the freq. changes rapidly you may not be able to find the exact point. I know this is a fine line, an oscillator that will swing over a wide bandwidth and yet be adjustable in a small bandwidth. So goes experiment.
All things are possible but some are impractical.
hartiberlin
Dear Ron,
so what exactly is exciting the coil-cores,
if you use just a ground wire ?
Can you try to find this out please ?
DrStiffler
Localjoe
Rstiffler said both these quotes on this thread ... Stefan wasn't off base at all for asking that question about the ground noise and single wire conductor
Getting somewhat concerned about what you do not understand, or do not want to. Where in this diagram do you see a parasitic plate or a signal generator.
Please stop trying to change or put works in my mouth because I will not just jump to the end.
4) The Al plate does not worth the same as mass does in Stefans example. When using a proto-board with the backing Al plate it need not concern you until you wish to use it as a parasitic amplifier, in which case you would drive the circuit by applying your signal to the outer most plate.
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
DrStiffler
Quote from: Localjoe on October 29, 2007, 07:26:19 PM
If you want to say something, say it, why extend the thread by some form of insinuation?
If you want to pursue the work great otherwise one could infer you to be another distractor  ????
