alchemist123
Quote from: Pirate88179 on May 22, 2010, 02:52:13 PM
What I don't get is that folks keep saying this is not an overunity device.  Well, consider that:
Input=0
Output=>0
How is this not ou?  Even my simple electrode circuit outside, which is still working, is ou.  My input is 0 and my output is enough to light 400 leds or some big floro tubes.
I don't want to argue on what the definition of OU is but to me, anything that you have 0 input and get >0 output has to be ou in its most fundamental form.
But you do have input, whether it is galvanic action or  a "telluric" receiver or whatever.   You still have normal electrical losses via heat and core losses from flux retained in the core after magnetization.  and eddy currents.
Now i agree that in a sense this is "free" energy, because all one has to is put some electrodes in the ground and wire it up and you got an electrical current,  but this is from the intrisic properties of the materials and system,  it is far from loss-less and very far from its output exceeding its input
Bruce_TPU
Quote from: alchemist123 on May 22, 2010, 06:58:15 PM
Who gives a rip if there are electrical losses via heat and core losses???  You have mentioned this three times in three postings.  These are not village idiots.  They have been working on this for a very long time.  And I with them at the first.
Why not build something yourself!  Oh wait... I know, it will have electrical losses and heat losses.  Sheesh!
alchemist123
Quote from: Bruce_TPU on May 22, 2010, 08:41:59 PM
I repeatedly mention this because it is easy to get lost an important message amongst the 200 some pages in this thread.   And not to mention it is the very problem that makes your logic flawed in your feedback idea and also the reason why this is not an overunity device.     How about you pick up a highschool physics textbook and learn a thing or 2 ok?
Vids will be posted in a couple weeks, running tests on various core selections and ideas on improving efficency
Bruce_TPU
Hello ALL,
Ignoring the above drivel...  H.S. physics books, yea, that's the solution.
Anywho, there is a man who has offered help in this feed back venture, but needs an appropriate circuit of the LaserSaber coil drawn out.  View his post here:
http://www.energeticforum.com/renewable-energy/2209-earth-battery-sg-17.html#post95972
P.S. alchemist123
There is no arguing, only experimenting.  You can say it can't be done all that you want.  They said the same thing to Steven Mark, Tesla, Columbus, and about a thousand others.  I know that there is unlimited power that can be tapped into.  I never accept the words "Can't" or "Try" or "not possible".  They told me I couldn't raise ocean shrimp in Fresh water.  Said I was "crazy", and "wasting my time".  Guess what, they were wrong.  The more you tell me it "can't be done" the more I will find a way!  That is what makes me, me.... ;)  All things are possible!!  Jesus walked on water, Peter took a few steps (more than we ever have), I have seen the lame walk and blind eyes opened, sir.  So... I would trade all of the physics books that say why it can't be done, for a couple of stubborn people who will not take "can't" for an answer and try, and experiment, and try again.  How many times did Edison try differant items for the filament for the first light bulb?  He was told it "couldn't be done", "not possible", and to "give up".
You have a good night with the status quoe... But me, I want to give the lightning to our children and to reach for the stars!
Cheers,
Bruce
Master_T
@All
I just wanted to say that I have had some very interesting results experimenting with the configuration that I posted before, but with a capacitor bank, three NS coils connected together and burried into the ground, and the involvment of an electric velder to effect the ground from several widely spaced points.
I could post the details up till this point, but I have a feeling I do not belong here.
I still wish all of you the best.
