What is Electricty What is Magnetics?
Started by innovation_station, November 05, 2007, 11:48:47 AM
sparks
@local joe
      Just trying to understand how increasing or decreasing a magnetic field creates emf.
      If the magnetic dipoles of the electron spin to align with the external magnetic field this results in a change in the spin angular momentum of the electron. If the spin angular momentum of the electron is coupled to the orbital angular momentum then there will result a change in the orbit of the electron. The uncoupling of the spin momentum from the orbital momentum results in a conversion of the orbital momentum into vectored energy.  As the external magnetic field stabilizes the dipole shift stops and the spin angular moment recouples with an orbital moment and current ceases.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Charlie_V
We don't know what they really are, we observe them as force fields.  In an oscillating system, the electric field stores energy like a spring, and the magnetic field stores energy like momentum in a moving mass.  People always assume that a moving charge creates a magnetic field, but can't the magnetic field create the moving charge?  How do we know which comes first?
Personally, I feel they are both states of energy.  The electric field is the potential energy of the universe while the magnetic field is the kinetic energy of the same.  Gravity is an affect created by them.  When these two forces are made to oscillate in phase with each other at a specific location, light is produced and radiates from that location.  At a high enough frequency, light will interact with the smallest particles of matter (the particles that make up everything, that makes up everything in an atom).  If light produces a perfect reflection with a particle, it will transfer twice the momentum.  This is known as radiation pressure.  If we then assume that a piece of matter is being constantly bombarded by ultra high frequency cosmic radiation from all directions, we have an interesting phenomenon.  If an object of matter is alone, then no net force is exerted on it, since the momentum transfer is in all directions.  However, if a second object is placed near the first, the ultra cosmic radiation is shielded on the sides of the two particles that face each other.  This produces an unbalance of force and the radiation pressure pushes these two objects together.  The more mass the two objects have, the greater the shielding will be.  This "shielding" is what we perceive as gravity.  So objects with large mass will exhibit more "gravity".  This theory then explains gravity as the absence of light (light at a frequency that interacts with the building blocks of matter).  This of course is only a theory that I read somewhere... but it makes a lot of sense and I like it - still doesn't explain everything, but what does?
If you read anything dealing with basic thermodynamic principles, you will quickly come to a realization - if everything is less than 1, and entropy is working to neutralize all the energy in the universe, then we should never have existed to begin with.  Therefore, since we are obviously here, the universe must have an opposite form of entropy, an ordering - basically there must be a way that the universe creates energy just as fast as it dissipates it away.  I think if people in the researching field would come to this realization, then a collective search to how energy is created could be accomplished.
Since the universe's foundation is based on electric and magnetic fields, the answer will lie in them.  To create energy, I think you need to have a way of producing changes without a reactionary force (or atleast with a greatly reduced reactionary force).  By applying a little force, you create a greater change that does not counteract your applied force.  In order to do this, you need a field that is self supporting, a field whose internal direction is different from its outward direction - something that interacts with the outside environment yet its flux returns to itself.  Well, right away we see that it can not be the electric field, since its flux is only in one direction, it radiates outward and does not come back.  An electric dipole has a direction of flux in one direction, both inside and out, from positive to negative.  However, the magnetic field is different.  A magnetic dipole has a flux in one direction on the outside and an opposite direction on the inside.  The flux radiates out yet returns to itself.... so it is in the magnetic field that will create energy.  This is where my research is at.
But after all that is said, I still don't really know what a magnetic or electric field is!
scotty1
Hi all....
Here is what Tesla said....
"The day when we shall know exactly what electricity is will chronical an event probably greater, more important than any other recorded in the history of the human race.
Then it will be a mere question of time, when men will succeede in attatching their machinery to the very wheelwork of nature....see the excitement coming" Nikola Tesla.
Researchers, experimenters and other people, read about Magnetic Current, then you will know what it is, how it is made, what makes it, and how it runs in a wire. Then you will know what the North and South pole individual magnets can do, THEN YOU WILL KNOW WHAT ELECTRICITY IS.
Ed Leedskalnin.
A semiconductor is an element with a valence of four, which means that an isolated atom of the material has four electrons in its outer or valence orbit. Electrons in the valence orbit are only weakly attracted by the nucleus of the atom, and thus, can be dislodged from the valence orbit to become free electrons. When a free electron is dislodged from the valence orbit, a vacancy is left in the valence orbit, called a hole. The hole behaves like a positive charge, which will attract and capture any electron in the immediate vicinity.
So we get positive charges from a vacancy? and the vacant spot can attract and capture electrons? then where does the positive charge go...back to nothing from where it came?
We get charges from nothing.. ???.....lol
Read about magnetic currents
Scotty
sparks
     I consider all matter as light resonating.  Light caught in a fleeting equilibrium of two forces willing it to be on it's way (anywhere but here) and a second force wanting light to be in one point. The absense of time/energy is inertia and standing waves.  Time /energy is what we all want to control.  Control of light energy so that time will be what we want it to be..   Light becomes the true commodity of life.  In an electron there is trapped light.  It isn't much compared to the sun prison but it is there.  If we add just a little bit of discord to the electron equilibrium then light, the energy of all life is freed.  Not for long though because the forces  will try to put it back under their control.  By using time/energy to mess with the fundamental forces we can upset the electron resonance.  From the electron will come energy in excess of the energy used to upset the resonance.  Like punching a hole in the bottom of a plastic bag filled with water.  Electricity is energy or time creation.  Magnetism is force controlling how light will travel and charge is force controlling where light will go.  We don't need to annihalate the atom or fuse it to another one.  Just give it a poke and let the light free.
Think Legacy
Spread the Love
scotty1
"I think that the North and South pole individual magnets are running in an orbit around a common core in an atom the same way as they run in an orbit around a common core in the perpetual motion holder that I made. The only difference is that an atom has a small orbit, but the perpetual motion holder has a large orbit. I have never seen an atom but i think the atom drawings are wrong. They should be drawn to fit the earth on account of the fact that the atom is a part of the earth. The earth has 2 magnet poles. This means that each pole has an equal pull and push to hold the earth together, and so each atom should be built as it could have 2 poles. In that case BOTH THE FORCES that make magnet poles should run around a common core (the core could be a particle of sunlight).....I believe that if some enterprising man would analize the magnet metal which comes straight from the earth, he would find that the metal is NOT BUILT UP BY PROTONS AND ELECTRONS, but by NORTH AND SOUTH POLE INDIVIDUAL MAGNETS"  Ed Leedskalnin.
Scotty
