Thanks to ALL for your help!!
Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Bruce_TPU
Quote from: sanmankl on November 22, 2007, 01:48:19 PM
Hi Bruce,
Here you go.
It's a high res photo. You can zoom in if you want. The lower wire is the "aluminium" type. The middle one, below the roll is the iron type.
Cheers, sanmankl
@sanmankl
Thank you for the picture.  I sure would like to find some insulated iron wire as you have there.  Should you or someone else come across where, please post the link for me.
@ All
I need some help please, trying to figure out how to tie the two identical circuits together.  I hooked emitter from one circuit to the emitter to the other.  It worked, but no addition of time.  Any ideas at all, please let me know.  Or draw me a little circuit.  Thanks!
Cheers,
Bruce
EDIT:  The picture below is for use in the AM Radio projects. Acts as a coil and an antenna.  I have ordered some of these as well as a few other things, from the link below.  I want to tie that antenna into the circuit and see what happens.
https://www.scitoyscatalog.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=SC&Category_Code=R
abassign
I have realized an experiment, but I have not had the good results of other experimenters and I don't understand where I have been wrong:
Transistor is: BC547C
Cond. are identical
Resistors are identica
Spool: 30 + 15
And try trigger loop with from 9 loop to 20 loop.
My LED operates only with the cathode inverted respect the scheme of EMDevice and this is rather strange.
After 3-4 minutes the LED switch-Off
have had the biggest problems in to start the apparatus:
I removed the LED to avoid that it was damaged (I have destroyed 3 of them...) I loaded the condenser with 10V I Inserted again ago the LED, and immediatly the LED start with a strong fast enad bright flash.
After the flsh it begins to pulse.
I have tried up to 12 LEDs in series, obviously the brightness reduced, but it didn't decrease the time of operation
The LED operates only with the cathode inverted respect the scheme of EM and this is rather strange.
I would be really happy if someone can give me some suggestions.
I also attach the images of the apparatus and the diagrams that show the descent of the tension to the heads of the condenser.
You will notice that in the diagrams the worse situation is when there is not the connected LED, when they connect him the everything it works, also increasing the LEDs keeps on working. Up to 6 LEDs with the same (apparent) bright intensity, after the brightness decreases.
I also have to notice that to around 2/3 of the discharge of the condenser, the blinking LED from 4 Hz passes to 2 Hz. The thing is strange I would want to know if someone has observed the same phenomenon.
Best regards
Adriano
Bruce_TPU
Quote from: abassign on November 22, 2007, 05:38:38 PM
Cond. are identical
Spool: 30 + 15
Best regards
Adriano
@ Adriano
The first thing that I would change is your wire, to 20 gauge magnetic.  My first attempt was with silver plated teflon coated, and it only runs a minute or two.
Cheers,
Bruce
hartiberlin
@abassign
with a reversed LEDit should not work !
Then you have a discharge of the main cap via the LED-coil !
Try to avoid breaking your LEDs by putting a diac across the tansistor emitter to collector,
this will chop off all voltage bigger than about 30 Volts,
or you can use also a neon bulb, but then the voltage will go to
about 80 Volts at the spikebefore the neon bulb will chop it off..
Bruce_TPU
Hello All,
Tonight I was able to increase my time by an additional 17%!  Someone had suggested a small cap between the base and emitter of my transistors.  It was several posts back, and thank you. I placed the small capacitor pictured below.
Final run time, with no battery and no power supply was 28 minutes and 4 seconds.  Again, this was two LED's in parallel, blinking.
I have ordered my barium ferrite coil cores, two different types, as well as some germanium diodes.  I am looking for iron insulated wire, and will also try nickel wire, and aluminum wire in the future.
I did experiment with two mirror circuits, but so far best time was just over 20 minutes.
I have just concluded an experiment with aluminum surrounding steel in the center of the ferrite coil, but no change in length of time running, whatsoever.
Cheers and good night,
Bruce
