Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Mannix
Iron wire is used to repair plastic coated ringlock fences....also it is used to tie vines and branches..plastic coating is to protect the plant ...iron is for strength ...it used to be used a lot to hold large  hay bales together..
Gardening supply stores and fencing supply stores are sources that should have it in one form or another.
You could make your own using any Iron wire and painting it...
4Tesla
Thanks Mannix!
Here are some mods I made to the circuit that might work.
Note: If the first one doesn't work, then the 150ohm resistor in the second circuit would need to be replaced with the trigger coil.
Edit: I have been thinking about the second circuit and I don't think it will work.  I was trying to think of a way to isolate the RC circuit while the capacitor in the RC circuit discharges.  I do think that the first circuit still can work.  If not with 150ohms, try 470ohms and 1k and then 10k and so on. - Thanks
4Tesla
Bruce_TPU
Hey Guys!
I tried to post this in the morning, but OU.com forum would not allow me for some reason.  Anyway, it is not hard.  I am using only copper 20 gauge magnet wire at this time I will wrap another toroid, when I run out of ideas on this setup and can no longer improve my time.
Here is my circuit.  Also I think the Toroid chosen is critical.  I think I lucked out in finding these nice ones.
Tonight I try feeding back the barium ferrite secondary and see if it adds time.
Holiday Cheers,
Bruce
4Tesla
Cool thanks Bruce!  How does the 220 capacitor effect the circuit?
Thanks,
4Tesla
Bruce_TPU
Quote from: 4Tesla on November 27, 2007, 07:04:36 PM
Thanks,
4Tesla
It was something that added self running time.  I posted the details some time ago and can't remember the exact number.  I have tried others there, but it works the best.  (give me the best run time.)
I have tried and will continue to try as many nutty ideas as I can think of!  ;D  The "Edison" way!  LOL
Tonight I will test the secondary fed back with and with out diode, in series, just one of the secondary, and also both leads of the secondary.  Tomorrow night I will test the coil core in the center of the toroid.  That should be interesting!
Holiday Cheers,
Bruce
