Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
FreqShift
Quote from: btentzer on November 28, 2007, 12:03:44 AM
Hello All,
Well, I have run my last test for the night.  No joy from any of my earlier tests, BUT on this last test, I took the wire going from the anode of the LED to the primary bottom winding on the barium ferrite coil core, and moved it to the negative side of the capacitor.  I have one lead of the secondary from the barium ferrite coil, going to a 1N4007 diode and from there to the positive side of the 1000uf capacitor.
The LED lit MUCH more brightly per flash.  To the point that it hurt my eyes to look at it!   ;D
Total run time was still just over 37 minutes, though.
A new round of tests tomorrow night.
Holiday Cheers and good night,
Bruce
Hello Bruce,
I have been following this thread after being captured by search engine into the "Mike Motor Forum".
I spent ten straight hours reading the "Mike Motor Forum" It is sad that Mike never returned to help out, and the forum dried up. (Why did you sell out Mike?)
Oh well, this is crackable without him.
Do you mind if I brainstorm a bit? I am only hoping to inspire you and the others.
Nature's 'expression' of mathematics has always fascinated me. And nature Is The 'Spiral'.
Have a look at this spiral motor:
http://www.youtube.com/watch?v=13JW-Ifg4wA
Now, mathematically, the spiral is related to the hexagon and the pentagram. Is this why Mike's motor was hexagon shaped?
It this why Saturn has a hexagon at it's pole?:
http://dsc.discovery.com/news/2007/03/27/hexagon_spa.html?category=space
http://www.goldenmean.info/fractalgravity/
Please understand, I do not subscribe to Dan Winter's views of philosophy or religion; but he may be on to something with his 'implosion' theory relating to gravity and electricity.
Note Mr. Winter's discussion on 'cone shaped' capacitors on this site:
http://64.233.167.104/search?q=cache:BqXgWt7TNToJ:www.zayra.de/soulcom/thrust/+spherical+dodecahedron&hl=en&client=firefox-a&hs=Nds&gl=us&strip=0
With All That said and done... You better have a look at this coil:
http://www.matter.org.uk/Schools/Content/MagneticFields/fields_3.html
Now the way I understand OU/befm. When a magnetic field collapses, it 'implodes' on itself fractally. Reaching into another dimension, reaching into the very machinery that runs the universe.
I just can not help but think that a key to this project lies in sacred geometry / and or frequencies.
Keep up the good work Everyone.
It looks like you have something there with that extra coil.
Can you get "this" LED to run?
http://www.techchee.com/2007/10/08/gigantic-led-is-a-lamp-that-is-made-from-dozen-of-leds/
You will eventually!
Ritchie
4Tesla
Hi FreqShift,
Welcome!  Cool Avatar!  Thanks for the links!
@all
Here is another schematic... as soon as I get my toroids, I'll test these circuits before I post, but until then, everyone is welcome to try them.
Edit: Not sure about the bottom diode.
4Tesla
Bruce_TPU
@ FreqShift
You wrote, "I spent ten straight hours reading the "Mike Motor Forum" It is sad that Mike never returned to help out, and the forum dried up. (Why did you sell out Mike?"
I was not a part of that thread, nor a part of whatever transpired there at all.  So if you were meaning others, it should be made clear, because it sounds as if you are speaking of me.  Thank you for correcting this statement in advance.
@ 4Tesla
I have tried 4 other transistors tonight.  Some are close with their time, one was far worse, by 10 minutes less on the run time.  And one did not work at all.
The transistor that works the BEST so far (unclear how my MPS3904 will do, when it arrives) is NPN 9011I.  What I would like is an experienced EE to figure out WHY this one works the best.   ???  Is it the frequency?  The others were stated at 200Mhz, 250MHz, and 300Mhz.  is it the voltage, amperage, what?  Then I can look for an even better transistor based on that criteria.  Thanks in advance for someone's help.
I think some diodes may indeed be in order.  I will think on and try some ideas, when my current test is complete.  If current test works, I will let you know and the details
This is the specs:
ALH
9011I
Si
npn
310mW
20V
18V
3V
50mA
135>C
50MHz
3.5
132MIN
HIN
TO92-2
Holiday Cheers,
Bruce
Grumpy
Quote from: 4Tesla on November 28, 2007, 07:38:42 PM
I'm not saying Tesla didn't get OU, but no one has got OU, based on his work, meaning no known working replicas.
4Tesla
Oh, I think many, many people have gotten OU from his work.   Just because they do not post there results on every forum or call a press conference does not mean they are not getting results.  Look what happened to Eric Dollard - crushed by the Power Mongers.
        -Frank Edwards
innovation_station
he was not called the fore father of free engery for no reason was he ??
ist
