THEORY on TPU energy scource
Started by sparks, November 14, 2007, 12:11:50 AM
scratchrobot
Quote from: Sequental.9 on October 12, 2016, 02:27:19 PM
I  have come under some kind of cyber attack ? A very bad one !!! I am sorry but I can no longer post here ! I hope the data provide has been of some help and I wish you all the best of luck with all wish for ...
Thanks for all the info and best of luck with all wish for ...[/size] [/size]
Goodbye
MasterPlaster
All the best ! lol x
LOL indeed.
Your drip feeding of information did not work. Now I have a half finished space craft in my garden that will go no where.
AlienGrey
Quote from: Sequental.9 on August 24, 2016, 04:58:45 PM
OK VORTEX ! Not a problem . But one has to let go of all they know and take on board there are many of us that tend to keep things private and for good reason, as the world is a bit tricky to balance and sometimes knowledge in the wrong hands is a bad seed of unknown realities.
But I also except that we all need a chance fro freedom and to that, I will begin to lay the path that will reward you with your goal ! First, these things are never found by theory as there are no theories that created them.
For now let go !!!!! START AGIAN !!!!!!
I will detail only the core transformer and one that is already on the market but it has this very interesting ability that does not relate to OHMs law but it is built by this law and there it should not do what it does.
This may come as a bit of a surprise but all 500 watt 2 AMP 240v to 275v AC variable transformers and also all the ones below that all have this interesting effect. And some of the old ones can hold a charge when you switch them off if by chance you had the right one and was messing around with it by shorting out the out put wire when in the off mode. Some will spark and even blow a 10 amp fuse or more.
But that is not the only thing it can do as on the QC mark it states a max voltage of 275 AC v but you get 330 V. All of these units produce the 330V so that is 55v over the QC mark. But you need the 240 to 250 v AC grid input to isolate the gain.
If you know how and what you can convert them to hold this magic charge but I will refuse to offer that out here and one has to give respect to the American for gaining hes patent but unfortunately its not worth a penny.
Who owns the combustion engine ? If you know what I mean ?
So you don't need anything but just a dumb transformer no secrets no head banging theory or a degree of the unknown as that is impossible . Where is there in this world a qualified zero pint engineer ? No such thing so no QC pass can ever be made ! This is a real problem for mass market use. And it is only a stupid off the shelf transformer, not an invention as its just an effect where we can all throw our worthless theory at it and compleat of such nonsense for the next 13.8 billion years.
Now this transformer just loves to give you abundant free energy but you're going to need a few more tricks for it to get above 100 watts and harmonics is how it is done with a guide of offsetting a gain in resistance !
Think water pipe like a garden hose and jump up and down on it as it flows, then bend it like a set of waves where each wave is bigger than the one before it . Think gravity and compare gravity to an electrical earth !
Think vacuum and measure the mass of the flow of water ! Know that the resistance is 7.76 G as the water travels up the wave in the pipe  but as it comes down it gains 9.8 G over a metre and the end result is one that can empty a swimming pool just with gravity.
The difference here between the water pipe and the magic transformer is one is water the other is electricity and the swimming pool is the transformer. But with a water pool it needs a lot of rain to keep a constant flow and is the same with the transformer.
The water pipe set up as a set of waves it also harmonics in electrical terms ! How many waves can you have inside a wave ? Well, it is always 2.2 trillion if each wave has the same potential of mass if each wave is a tiny bit faster so we can have a saturated field density inside each wave. Speed is equal to volts so as each wave harmonic is set under and inside the wave above not only is it best to increase the volts as to keep the overall potential constant for each wave added.
We can now say that there are 2 transformers one as the pool as a collector and the other as the field density amplifier and the final part is the load and the rain that keeps the pool collector full over infinity.
Keep it simple isolate the collector and the amplifier than work out your load and keep you working temperature at no more than 40c as at 80c you encounter electron permeability and depletion of the effective work of the field.
Maplin does a cheap 500 watt 2 amp transformer for £80 but in the small TPU he has a 1 amp core at around £40 but this gives you a good start on it with very little money . The more advanced ones have different cores and a bit of this and that ect ect .
Look again at the water pipe can you see in your mind many hills where each one is bigger than the next ? This in electrical terms is a gain on resistance and EMF would normally leak out at the high potential in each hill or wave in the pipe. And there are many ways to increase the resistance and counter use the back emf to overcome it and increase the flow of the current.
I have a 12 KW type system but to keep it producing a high field density I chose to add virtual particles and it keeps my system cold and helps me stay at low volts DC .....
But keep close to your TPU LEARN THE BASIC SET UP AND ISOLATE YOUR FREE ENERGY CURVE .......................................!
No need for the theory of how the pool collector transformer is kept constant for now! All I can say on that is each proton is equal to 1 KW of pure energy and all electrons are but one field one source of power throughout the universe.
You only need to say 10 of these transformers to power your home using the grid as the attractor and the transformers as the collector and then you have no electricity bill .......
But if you tel that to the energy company they will inform you that energy amplification from there grid also belongs to them and they will accuse you of energy theft ! They know !
But for now just buy the dumb stupid 1 or 2 amp transformer from Maplin and confirm the 330v AC at 55v gain over the QC mark ! Do it NOW ASAP ...........Than we can go to the next level and get you off the dam grid without problems from patents or governments or greedy evil energy companies.
Avoid the 3000 other youtube examples of crap or out dated heaps of junk or the buy me now head bangers !!!!
I am here now .....................GOOD LUCK !
S9
Does this idea really work ? after all it's just an autotransformer, wont it have loss just like any other device
AlienGrey
So where does the silver wound transformer come from, or can I use an RS type to test the phenomena  and how is it connected up and won't it need capacitors the tune the phase, not to mention the use of an Earth leakage trip for safety ? and it's nothing to do with a QEG device.
http://uk.rs-online.com/web/p/products/8902765/?tpr=3
AG
Turbo
Quote from: AlienGrey on October 19, 2016, 08:32:41 AM
AG
Dear AG,
You don't need that.
The only thing you need is a piece of wire and a voltage source.
No transformer no mass circuitry just a piece of wire and a voltage source and a means of measuring what comes out of it.
This is enough to generate / observe single kicks.
In this example the effect is electrostatic, open loop.
Autotransformer, you mentioned it above ,yes this is correct.
It's the same wire used in above example but formed into a coil with several tap points.
Next step you create multiple electron flows in that coiled wire.
In stead of observing only the electrostatic effect, you now start to see also the magnetic effects.
The fields generated bump into each other this causes the vibrating sensation in just the one wire/coil.
Now at some point, voltage / wave length / wire length / circumference starts to play a part.
But it is easiest to start by looking at these coil sections as completely separate circuits, so then you can experiment and find out how to drive them in a way that they start to interact with each other.
You can check the documentation i made some years ago.
Read for example the following quotes from Mr Mark:
I told you that the simplest form of over unity is a piece of wire and a voltage source.
Anyone can actually connect it and measure.
See for yourself the kick.
NO coil no xmrs, just a kick.
WE are not talking about a coil or a transformer or anything developing a primary to secondary flux.
We are just talking about a straight piece of wire, some electrons and a method of measuring what comes out of it.
Tesla states that you can have all kinds of electrons flowing through a wire traveling in different directions relating only to their potential power source.
He even said that you could have different electron flows through a single wire completely separate from each other.
I tried it and he is right!
The two transformers get slightly out of phase with each other.
I became interested in the interaction between the two AC transformers.
The interaction can be very reveling, trust me.
In the case of my power unit, you create several frequencies within a space of the collector coil's circumference.
The frequencies are directly related to the circumference of the collector coil.
So simple but at the same time so difficult, because it leaves the textbooks.
The classical formulas for power calculation do not deal with a wire that uses or is connected to several sources / multiple electron flows.
But i can assure you, if you do these simple experiments it will not take long for you to develop the understanding that you need to proceed.
Why don't you give it a try?
If you have any questions, or something isn't clear, just post it,  i will be happy to help.
