THEORY on TPU energy scource
Started by sparks, November 14, 2007, 12:11:50 AM
Rosphere
Quote from: tao on November 14, 2007, 10:48:16 PM
http://montalk.net/notes/the-etheric-origins-of-gravity-electricity-and-magnetism
"Electric Scalar Potential (Voltage)
Another distortion in the superpotential is one where the value changes over time...
Thank you, tao.  I found this interesting:
Quote from: http://montalk.net/notes/the-etheric-origins-of-gravity-electricity-and-magnetism
When the current is pulsed, it creates a gravitational shockwave in and around the wire. Electrons drag ether along with them, and when electron density changes rapidly, so does the ether density. This is why wires given strong current pulses mysteriously break apart into segments as though pulled apart by internal longitudinal forces, and why rail guns buckle in ways that cannot be explained by mere magnetic forces.
Well, the whole concept is interesting.  The author mentions J.C. Maxwell, as well.  I am almost done reading it.  I will need to go over it a few times to make sure that I understand it correctly.
Thanks again.  :)
Grumpy
        -Frank Edwards
Moab
NightBlade
Quote from: devilzangel on November 15, 2007, 01:45:20 PM
have it your way. http://en.wikipedia.org/wiki/Coriolis_force .. now now, read carefully. The first few paragraphs are key. (I agree wiki isn't an academic source, but it gets the point across here very well)
ok i will give this a whirl then, lets see where it leads: Are you implying the rotation of the earth is the energy behind the TPU (it isn't the Coriolis force that initiated the rotation in the first place), and that the Coriolis Force is the conduit for this flow? This would mean that if i was in space in non-orbit, the TPU would not work. Or would it? Does the whole galaxy exhibit Coriolis Force? ..
The Coriolis Force is a derivative of other interactions. An "effect" of interaction between other energies. Ultimately, one could say, that the Coriolis Force is simply a gradient of gravity.
devilzangel
Well, I do know that Steven Mark mentioned that it wouldn't work upside down...  :D
Esa Maunu
Quote from: -[marco]- on November 14, 2007, 03:04:36 AM
Hi,
The energy comes from mother nature.
We disable the effects of the magnetic flux, so the electrons are able to float around freely like the wind...
M.
Marco,
It is just as you said. But there is also more.. If we are able to compress the zpe field with a devices like TPU, it leads to artificial gravity fields. In a gravity field there is a spacetime curvature, that leads to time dilation. Now, if you create this compressed time field temporarily, with input pulses, it happens that the magnetic energy that is created in a coil, is formed in fact in your near future. When you shut off the pulse, the time is returned to "normal" time frame, but the magnetic energy you just created, is still there, in a near future and has nowhere to go. When time goes forward, we reach this time frame, where the magnetic energy is, and we can tap it to our output coil.
This is just one thing of many that we can do with this technology. Like with all things, this coin has also two sides, and the big question is that are we ready to use this technology ?
Esa
