Reasons for not building a TPU like the one Steven Mark's had in 1998
Started by sparks, December 01, 2007, 09:55:34 PM
Grumpy
Quote from: kames on December 08, 2007, 10:05:58 PM
Quote from: Grumpy on December 08, 2007, 10:32:39 AM
Quote from: zapnic on December 08, 2007, 08:57:12 AM
I even gave you some easy to obtain references to this phenomenon in a
few technical journals
"little mystery what are these journals?"
Got those  references handy?
YES
Then what are they?  I'd like to check them out.
        -Frank Edwards
kames
Quote from: Grumpy on December 08, 2007, 11:54:00 PM
YES
What is public is public, what is private is private. I can give you only public references. I won?t provide any pictures or drawings. The time has gone for it. Search the web for ?moving electron mass by potential?. It does take a very careful reading and going into a math a little. It took me about 30 articles to go through before I could understand a lot of things for myself. Otherwise, it would be very difficult to understand what can possibly change the electron potential and how to do that in practice and a lot of things described by SM. What I have found resulted in forgetting all my old tpus and building a new one that looks like the very first open tpu in the SM?s video.
Kames.
Grumpy
        -Frank Edwards
starcruiser
Here is a few Ideas I am going to try over xmas vacation. The idea is to use a blocking type oscillator and use a torrid coil for the oscillator. The feedback loop is to locate the torrid close to the flux field so the oscillator is influenced by the collectors. The output of the collectors can be (I will try this also) connected to a capacitor for charge storage and to create an LC network. The capacitor value, I think, should be selected to tune the collector circuit to oscillate at a harmonic of the primary oscillator (kicks anyone?). The magnet is used to couple the coils provide some magnification and perpetuate the oscillations since the Blocking Oscillator would not have a feedback coil wound on the torrid but get its feedback signal from the flux field which is amplified/coupled by the magnets field.
The coils I think should be wound non-symetrical, i.e. oval shaped (SM's design shows this for his TPU's)
I got this idea from the leedskin designs and the open frame TPU. All of SM's TPU's have a small Torrid which might be part of the oscillators tank.
As for the oscillators operating frequency, maybe one of the frequencies mentioned by SM or maybe the NMR of the coils material.
This should be simple enough to put together and test this theory of mine.
Carl
dutchy1966
Quote from: Grumpy on December 07, 2007, 11:43:20 PM
EDIT:  notice somthing odd about that rotating magnetic field in the TPU when it first starts up?  SM they found that the drection was opposite in the southern hemisphere - not that it had to be opposite - that is was.  This is a secondary effect.  What about the statement that the compass spins and then just stops and when it stops the unit is at about it's max.  What sort of change to a wave would cause the compass to stand still?
Hi Grumpy,
Is this an actual phrase from SM or did you reword it? The only bit i know about is where SM commented that in the southern hemisphere it works in reverse. Not mentioning WHAT exactly works in reverse....
If SM did actually say it like in the phrase then the RMF is indeed a secondary effect....
regards
Robert
