The Secret To The Entire Universe - I Want To Tell You All
Started by 0ne, December 03, 2007, 05:49:43 PM
Moab
Great post!
Quote from: PhiScience on December 05, 2007, 04:43:18 PM
Hi all,
Here is some info on the Ether-Vortex Theory.
With the exception of radiant pressure, there are only three elementary forces that act at a distance; gravitational, electrostatic, and magnetic forces.
The ether-vortex theory seems to furnish the answer as to how three such forces can act independently of each other in the same space and at the same time.
According to the latest views, the force of gravity is caused by a pressure of the ether, rather than by a movement thereof.
If there is present only one body, and it is spherical in form, the ether will be in the same condition on all sides of the body. IF, however, there are two bodies close to each other, as in the case of a double star, then the condition of spherical symmetry will no longer exist, but instead, there will only be axial symmetry.
The ether currents of the two bodies will then organize themselves into the form of a bipolar vortex, similar to the field around an electron; but on a much larger scale.
The effect of this vortex will be to create a difference in pressure on the proximate and remote sides of the two bodies.
The ether in the space between the two bodies will be at a lower pressure than at their remote sides; and such a difference in pressure will push the two bodies toward each other, and cause them to fall into each other, unless they are in orbital movement about each other, so that centrifugal force will keep them apart.
  Electric and magnetic forces are caused, not by pressure of the ether, but by movement of the ether in the form of whirls, or eddies.
These exist on a much smaller scale and are more localized than gravitational fields of force.
Since whirls and eddies can exist regardless of the pressure of the ether, it is readily seen why electric and magnetic forces can act independently of gravitational force; and vice versa.
  There now remains only the superposition of electric and magnetic fields upon each other, either coaxially, or transversely of each other (as we have in the Great Pyramid).
In this consideration, let us consider first, their coaxial superposition.
  An electrostatic field consists of a flow of ether in a direct line from protons in the positive electrode, to electrons in the negative electrode, and then back again to the protons through outside paths.
If the electrodes are made of iron, and are magnetized, with the N and S poles facing each other, then the magnetic field will consist of a rotation of the ether around their axis of symmetry; and such a rotating or spinning movement of the ether can occur simultaneously with the circulatory movement that corresponds to the electrostatic field.
A magnetic field, can, therefore, be superimposed directly upon a coaxial electrostatic field.
  If the magnetic field is superimposed transversely upon the electrostatic field, then both fields will be distorted, but not destroyed. The circulating ether which constitutes the electrostatic field will no longer retain its axial symmetry, but it will, nevertheless, continue to circulate.
Similarly, the rotating ether which constitutes the magnetic field, will pursue irregular and non-circular paths; but it will continue to rotate. A magnetic field can, therefore, be superimposed transversely in any direction upon an electrostatic field, without interfering with the latter.
  An example of the transverse field effect is demonstrated in a pyramid. In this case, there is a shaped electrostatic field due to the structure of the pyramid, and the action of the earthââ,¬â,,¢s magnetic field on the resultant shaped ether flow. The result of these effects would be the formation of a rather large ether vortex in the pyramid.
  The ether-vortex casts some interesting probabilities on possible interplanetary travel.
  Gravitational forces and inertial forces are due to interaction between material bodies and the ether. Instead of trying to control a body by acting upon it directly, it may be possible to control it more effectively by acting upon the ether, which in turn controls behavior of the body.
A change in the state of rest, or motion, of a body is always caused by a difference of ether pressure on opposite sides of the body.
Thus, in the case of two celestial bodies which attract each other gravitationally, the ether pressure in the space between them is less than on their remote sides.
  Such a difference of pressure could be neutralized if some of the ether could be transformed from the high-pressure side to the low-pressure side.
Since the ether is a fluid, it should be capable of being moved from one place to another.
An ordinary bar magnet will not serve this purpose because the N and S poles are mirror images of each other; it being now well established that the ether circulates around the magnet, and not out of one pole and into another.
If a series of magnets be arranged end-to-end so as to form a closed ring, there will be an external ether circulating, similar in form to a smoke ring.
If two of these cores be placed face-to-face against each other, in such a manner that their circulating ether currents are in rolling contact; that is in rolling contact with each other, they will form a large scale replica of either the vortex proton, or the vortex electron; depending on whether the ether in the space between them flows inwardly, or outward.
An electrostatic condenser also produces a similar transfer of ether.
If protons and electrons are dipolar vortices with two vortex rings in rolling contact with each other, then in a charged condenser there will be a unidirectional flow of ether from the protons of the positive charge, to the electrons of the negative charge; the return flow being either around the edges of the plates, or between the molecules of the dielectric.
  These magnetic and electrostatic devices can be combined in many different ways.
By the proper arrangement, and by the use of personal controls, it should be possible to maintain a regulated flow of ether through such a system in any direction; into or out of it, so as to change the ether pressure in and around the system.
Perhaps the Egyptians used such a system to transport the huge blocks of stone in the Great Pyramid.
  A comment will probably be that such a system would be contrary to the law of conservation of energy; a violation of the first law of thermodynamics.
This law, however, applies only to isolated systems, and a process that involves the transfer of ether to and from the outside, is hardly an isolated system.
There is much we still do not know about the law of conservation of energy.
  In spite of all the glamour of modern technology, the orthodox science of today is still unable to draw a single plausible picture, or diagram, of even the simplest elementary particle, or to give any intelligible explanation for any of the forces that act at a distance.
  The ether-vortex theory would give us a new method of approach, and may open up a new field for experimental research.
First, we should try to find some method of producing regions of increased, or decreased, ether pressure, and then study the effect of such conditions upon the elementary particles of matter.
  If we merely continue along the present lines of thought, then the problem of producing an anti-gravity device will probably never be solved.
It may be troublesome to change over from a nucleated atom to a vortex atom, but it will be still more troublesome ten or twenty years from now, and eventually the change will have to be made, for there is a continually increasing amount of evidence that is piling up against the nuclear theory.
  It is significant that the physics profession has never made any effort to attack the new vortex theory of the atom.
Any evidence that can be produced in support of the nuclear theory is equally applicable to the vortex theory, and the latter can explain many things that the nuclear theory cannot explain at all.
It is only the vortex theory that has been able to offer any suggestions as to how we may proceed in our efforts to solve the problems of biocosmic energy and of anti-gravity.
PhiScience
Quote from: 0ne on December 05, 2007, 06:47:33 PM
..anyway.. my theory is different then all others. The post above was interesting, but very misleading.
Gravity is easy to understand, it is JUST MAGNETIC FORCE. I will explain later... while you all wait, please explain to me why you think gravity and magnetism are different. Then I will explain how weight works....and how the heavyer the object, the easyer it is to levitate.  I will also explain anti-gravity, and how you use it all day every day..
  There are three, and only three, elementary forces which act at a distance.
Gravitational, electrostatic, and magnetic forces.
It has been argued by relativists that gravitation should not be included in the same category with electric and magnetic forces, but should be interpreted as a curvature of space, rather than a physical force.
  Such an interpretation does not seem to be required by the observed facts, and would only introduce ambiguity and confusion.
Gravitation is a physical force, because it changes the state of rest or motion of material bodies, and therefore requires a physical explanation.
  The argument of the relativists, that since gravitation cannot be screened, it must be something intrinsically different from the other forces of nature, is plainly fallacious because the apparent screening of electric and magnetic forces is really neutralization, rather than screening.
Electric and magnet forces have polarity, and will therefore cause dielectric, or magnetic polarization of the material bodies on which they impinge whereby opposing electric or magnetic forces will be set up, so as to counteract the effects of the original forces.
The reason why no such effect can be produced by the force of gravitation is because gravitation does not have polarity, and not because it is of more fundamental origin than the other forces.
  It has also been suggested that gravitation may be due to a slight preponderance of the attractive, over the repulsive, forces between the elementary electric charges.
The difficulty with such an explanation is, that even a small residual effect would still have the same polarization as the original forces, and would therefore be subject to neutralization, or so-called ?screening?.
  It is meaningless to talk about the force of gravity unless there are at least two material bodies, or their equivalents, between which the force is considered as acting.
There will then be only three theoretical possibilities: they may either attract each other, or repel each other, or have no effect on each other.
If the two bodies were entirely discrete and self-contained, they would have no effect upon each other; but it has already been explained that the subatomic particles of which such bodies are composed, probably consist of vortices in the ether which keep the surrounding ether in motion.
Except in the immediate neighborhood of its origin, such motion will be random and disorderly, somewhat like the movements of gas molecules, but the moving portions of the ether will be elongated streamers, threads, or jets, rather than point like particles.
  Those streamers which have the highest velocities will move furthest away from the bodies in which they originated and will eventually encounter the streamers from the other body.
Since the ether is presumably incompressible, these streamers cannot pierce one another, but must be deflected, and the only direction in which such deflection can occur is in the outward radial direction in the common equipotential zone between the two bodies.
The flow patterns of the outwardly directed streamers will therefore be different in the region between the two bodies, than at their remote sides.
In order to compensate for this concentrated outward equatorial flow of the ether in the region between the two bodies, there must be an equivalent inward flow which must occur mainly at the remote sides of each body.
Two material bodies within each other?s field of influence will therefore set up a circulatory system of external ether currents similar to that of the electron, but on a much larger scale.
The reverse of this system, which would be similar to that of the proton, can never occur on a large scale because it is only the outwardly directed streamers which will collect in the equipotential zone between the two bodies.
The resultant flow of ether will, therefore, be through each body, in the direction of the ether, which is probably the cause of the force of gravity.
The function of science is to make observations and measurements and to find correlations between the observed facts.
sparks
     I don't know if we are talking about the same thing but I believe there is round energy matter  (quonta assembled in a vortex) and there is linear emitted energy matter (quonta assembled in linear form.)  Some people are calling the linear assembled energy "black energy".   Gravity is a relationship between vortex energy  systems while magnetism is a relationship between linear energy systems.  Since man has evolved into a system that uses vortex energy we are able to see and feel vortex energy from other systems of vortex energy like the sun or the earth or another human being or a rock dropped on our toe.   Our thoughts and ability to imagine and dream and love and hate comes from the organization of linear energy in our life form.  We are both forms of energy.  Balancing these forms of energy in our life experience is not easy.  Living in your thoughts alone is dangerous to your body.  Living in just the carnal is dangerous to your thoughts.  Throw in the soul game players who want us to be like them:
pure carnal energy or pure thought energy and things are getting pretty fuckedup for mankind.   ::)  Bout time for the soul game players to help mankind instead of using them for game pieces in some kind of fuckedup prideful game.  Pride goeth before the fall maybe humility goes before the rise.
      Anyway I include a link to my post on gravity manipulation by man for man below.  Please consider it when exploring these wonderful machines man has been able to imagine and make.
http://www.overunity.com/index.php/topic,3717.0.html
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
0ne
I am going to tell you more about magnetism... this will help electrical engineers, or beginners, like it did Tesla. This information has probably never been published in the manner I am going to.....
Imagine a permanent U magnet..... When you look at the U magnet, all you see is the metal. What you don't see is the magnetic force that is trapped in the metal, circulating. It's common theory that the metal creates the magnetic force, this is very untrue. The magnetic force is only extra force that was trapped in the metal. The metal does not create the magnetic force.
This magnetic force is 2 clouds of really small magnets in many numbers. These subatomic monopole magnets can penetrate through any substance in the world, with very little resistance. Dirt, Wood, Rock, Metal, Flesh, Water, Air, and Everything. When they pass through dense objects like metal or rock, they move very quickly, only because the atoms of the dense objects are closer together. When magnetic force travels through air, it travels slower, because the atoms of air are far apart. Magnetic force travels faster in metal than it does through air, remember that, it is a law. If you have ever played with a magnet with edges, you would notice the magnetic force is more strong on the edges. This is because when the subatomic magnets pass through the metal and reach the edge, it has trouble exiting the metal, and is delayed because of the resistance of air. It's like a "traffic jam" of magnets on the edges. Because of the pointed edge there are more magnets building up in a smaller area. Sphere magnets don't have that problem.
Imagine the U magnet again, on one side of the U metal is North Force (NF), the other South Force(SF). The first law of magnets is "Likes Repel, Opposites Attract". So the subatomic magnets that make the NF attract over to the SF side, and then run around the U loop in a clockwise twist, back to where it started. The subatomic magnets that make the SF attract over to the NF side, and then run around the U loop in a clockwise twist against the other force, back to where it started.  This is the basics, I know, but there is more. NF and SF can NOT circulate without each other. They ALWAYS run against each other. If a NF is moving, there is a SF helping it.
Imagine now a 12 foot wall, with a rope thrown over the top, not fastened to anything. Now imagine a guy named North on one side of the wall, and a girl named South on the other side. North is attracted to South, so he tries to grab the rope and use it to climb over the wall to get to South. The rope slips and he has no chance. South is also attracted to North, so she tries to use the rope and climb over as well, but fails, because the rope is not fastened. Later, when North and South both are touching the rope, and they both climb it at the same time, the rope is fixed in place and they both successfully reach each other at the top. They needed to work together in order to reach each other.
Picture now, 1000's of North guys in a single file line, and 1000's of South girls in a single file line, all waiting for their chance to climb the rope and meet each other. Little did they all know, they are ghosts, and can pass through everything. So when the guy and girl met at the top of the wall, they hugged each other, they passed right through each other, and become attracted to the next guy/girl in line. Then they hug, and pass through, and get attracted to the next, and then the next, and the next, and repeat until the line stops.  If the line was a loop, they would hug and pass each other over and over, infinitely.
Now imagine again the U magnet. The shape of the U magnet metal isn't a closed loop, it is missing the top, but magnetic force is still traveling through it because it is jumping the gap at the top. When the subatomic magnets jump the gap at the top of the U, some are lost into the Universe, and only few are replaced from the Universe, and the magnetic force slowly leaves the U magnet. The Universe is a sea of magnetic force, so it is free in unlimited quantities. When you put a metal bar across the top of a U magnet, you can call it a "keeper". This closes the loop of the U magnet so that the NF and SF can attract and hug each other forever, without getting lost into the Universe. When a U magnet has a "keeper" bar on top, all of the magnetic force in the U magnet is trapped forever. Or until you remove the keeper, then the magnetic force tries to find the nearest attraction.
Here is an experiment. Order about 50 small sphere magnets and link them together in a loop, like a ball-chain. Put them next to a CRT monitor, and you will see the magnets have little to no effect on the CRT. Right when you break the loop of the sphere magnet chain, the magnetic "ring" is broken and they escape into the CRT monitor, discoloring it. This shows that magnetic force acts differently when they are in an infinite loop. Magnetic force can be bent, looped, consintrated into a beam, and can make pretty much any shape in the Entire Universe because everything in the Entire Universe is made of magnetic force, and everything is only different because of its shape.
Now let me tell you about "electricity". "Electricity" can not be created without magnets. Alternators, Generators, Dynamos, they all use magnets to create "electricity". Some genius's might say that solar panels don't use magnets, but they do. Maybe not human traditional man made magnets, but the panels are made of electrons and protons, and collect magnets from the Sun, our Father.
Traditional science also claims that because "electrons" pass through a wire, a magnetic force is created outside of the wire. Well, that is a giant lie. The wire has a magnetic force around it because MAGNETISM IS RUNNING THROUGH THE WIRE. "Electricity" is only magnetic force traveling in a stream through wire. Magnetic force can not travel through wire unless both North and South force is present. "Electrical wire" acts like the "keeper" on the U magnet. When you short an "electrical" circit you are pretty much creating a U magnet with a "keeper". A U magnet with a "keeper" would act exactly like a light bulb filament if the metal was smaller and a strong amount of magnetic force was in it. This will make understanding "electrical" components much easier.
A capacitor pretty much makes use of the "traffic jam" effect of magnetic force. When the magnetic force travels to the edge of the metal plate on one side of the capacitor, it has trouble passing through the dielectric, because it is less dense than metal, so there is a "traffic jam" on the first plate. This "traffic jam" is actually a build up of magnetic force. Sooner or later the magnetic force will be strong enough to reach beyond the dielectric, and make it through  onto other plate and out of the capacitor.
A resistor pretty much works like a light bulb. When the magnetic force is channeled through a very small place, the entire power of the magnetic force is trying to pass through, but some of the magnetic force escapes because of the resistance of the filament. And that creates "heat". Heat is just magnetic force traveling at a higher rate.
A vacuum tube is almost like a light bulb and a capacitor. The filament is "heated" with magnetic "alternating" current, and that heat gets trapped in a dielectric glass because of a "traffic jam". That makes it much easier to be caught and attracted to the anode and channeled out of the glass in direct current. If you put a magnetized "control grid" in front of the anode, you can change the resonance of the magnets before they enter the anode. Think of a pressurized water tank with a hole in it. The hole being like an anode in a vacuum tube. Water, and Air "pressure", acts exactly like magnetic force, because they both are made of magnetic force.
The reason you need to have a complete looped "circit" with "electronics", is because magnetism can not run through anything unless there is both North and South force present. THERE IS A WAY TO GET "ELECTRICITY", OR MAGNETISM, TO RUN THROUGH WIRE USING ONLY THE MAGNETIC FORCE THAT IS ALL AROUND US[/u]. Just tap twice.***
Also.... THERE IS ONLY 0NE[/u] FORCE. THAT IS MAGNETISM. GRAVITY DOES NOT EXIST, IT IS ONLY MAGNETIC FORCE. THE ENTIRE MASS OF EARTH IS COMPOSED OF ONLY ELECTRONS AND PROTONS AND NEUTRONS. EACH OF THOSE SUBATOMIC PARTICLES ARE TOUCHING EACH OTHER AND THEY ARE ALL CREATING 0NE GIANT STRENGTH.
The Earth is exactly like an atom.  We live in one of the outer "electron shells". Since 0ne law of magnetic force is that "magnetic force decreases with distance" that means the closer to the center of Earth we get, the more strong "gravity" is. The further away we get, the weaker the "gravity" gets. It's so simple to observe... don't let the lies get to you!!!
Let me explain to you the lies in science. In this world, they only hand us a "base belief". Normal people will take this "base belief" and live their entire lives not even questioning it. The people that do question it, and look into it, and learn on their own time, or learn beyond the "base belief" are the ones that find the truth. Here is an example of lies, and deception, in science.  First, they STILL teach the different layers of Earth in science class. Inner Core, Outer Core, Mantle, Upper Mantle, Crust, all those layers are being taught to everyone as if it was TRUTH!!! The REAL TRUTH is, no man or device has EVER traveled to the center of Earth, heck we haven't even made it past the CRUST!!!! THEY EVEN TEACH THE LAYERS OF THE SUN!!! IMPOSSIBLE TO PROVE! Here is some deception for you... They split "electromagnetic radiation" into "types", and make you think they are different in some way.. radio waves, microwaves, terahertz radiation, infrared radiation, visible light, ultraviolet radiation, X-rays and gamma rays, are ALL THE SAME THING, MAGNETIC FORCE!
...to be continued...there is more to it.
I will tell you about the magnetic breath of life next. Then back to anti-gravity.
evanlocc
Quote from: 0ne on December 03, 2007, 05:49:43 PM
...well..... everything happens for a reason, and nothing is an accident.
yes, everything even our imaginations !
THINK   d o e s   MATTER
