The Secret To The Entire Universe - I Want To Tell You All
Started by 0ne, December 03, 2007, 05:49:43 PM
Koen1
Ah, right. So magnetic "flux" is actually a stream of extremely small monopolar magnets?
Or is it 2 streams?
Interesting... since magnetism cannot exist without 2 opposing "poles", how do you propose said monopole magnetic particles exist?
Seems to me the entire meaning of magnetism is lost if you try to make a monopole... Spin simply does not work with monopoles...
Why would a magnetic field have to consist of "particles" that "flow"?
An electric field also does not consist of flowing particles... It consists of a potential that spans a specific area of space.
Particles carrying electric charge will move along the 'field lines' of this electric field. But the field itself exists before any charges are moved through space.
Magnetic fields, similarly, do not consist of "flowing" "particles". It consists of a spin gradient that spans an area of space.
Particles that have spin may move along the 'field lines' of this magnetic field. But the magnetic field exists before the magnetic particles interact with it.
It seems to me that One is too strongly attached to the idea that everything is particles.
sm0ky2
Magnetic Monopoles travel in a helix, twisting on one another, in opposite directions.
when one is not present, the other remains stationary (similar to a static charge)
in order to detect a magnetic monopole, you would first have to create one of opposite polarity.
( e.g. a     s. monopole could detect a n.)  a  dipole magnet would not be able to distuinguish between a monopole or a ferromagnetic particle. This is beacuse the monopole magnets are not moving, as they lack the opposing force. They can however be alligned by a stronger magnetic force, giving them ferromagnetic properties.
When both monopoles exist within a system, together they form a larger di-pole magnetic force.
which can effect other systems around it.
understand that before he rambles on about the formation of life. it will help you understand what hes trying to say.
wattsup
@Koen1
I think One is right on the money and I re-read his post and everything seems to  hold in place well.
I was thinking the same thing about monopole. There is not much out there on the subject. Even Wiki has little on it but they do quote Maxwell. http://en.wikipedia.org/wiki/Magnetic_monopole
Some patents have also tried to make monopole magnets using many metallic structures to cut off one of the poles.
Just to test something very simple, (see photo below), I took a ceramic rod and wound 10 tight turns of magnet wire, then continued with 10 spaced turns. One would expect that the center neutral or void location would be in the middle of the total winding, but it is not. Even though both polarities have the same number of turns, the north pole is taking up more space then the south pole.
What may be happening is that when a magnetic particle exits the North side, it is majority north polarized. Same for the South side which is majority south polarized. This is why when you put your compass to the magnetic center point, it stays neutral.
I don't think One means by monopole as having only one absolute pole as this is practically unimaginable to exist in nature. But most likely that one pole is dominant, and that the field movement is so fast that these monopoles do not have enough time, once out of the structure, to balance their polarities, and hence are automatically attracted to the other polarity, creating the magnetic loop.
allcanadian
@koen1
QuoteIt seems to me that One is too strongly attached to the idea that everything is particles.
It seems to me that you are too strongly attached to the idea that everything is not.
Henry.T.Moray believed matter and energy are one-always in motion, particles vibrating at a frequency near 500 Terrahertz, 500 Trillion cycles per second. If this is true all of us are delusional, we see a static image on our television and we say it is immobile but I know it is only pixels turning on and off nothing more. There is reason to believe these particles act in the same way, motion simulating rest, magnetic or electric the particles lower there combined frequency to form matter and raise it to form energy when released from matter. I do not know nor could I say if these particles are magnetic or electric because in the context given they would act the same. What I do know is most people believe everything they read in books----the others make history.
