The Secret To The Entire Universe - I Want To Tell You All
Started by 0ne, December 03, 2007, 05:49:43 PM
ambientcoil
ONE, a lot of what you said is correct.  This is a great forum, full of intelligent minds all searching for the same thing.  I think that someone from here will find what we're looking for.
mdlarouche
Quote from: truesearch on January 25, 2011, 11:56:23 AM
@mdlarouche
I hope that you come through with a design that you can share with the OU community. Most of us are searching for a verifiable design that we can duplicate.
Still searching. . . .
truesearch
As you can see from my post, my intention is to create a hardcore movement that will be able to perpetuate itself. I want it to work in such a way that even those with less financial means will be afforded the ability to have one...It will be built into my system as I described earlier. My intention is to obtain a patent but don't let that scare you because my reason for the patent is simply to prevent some large corporation from putting it on a shelf and preventing it from propagating. When patents are obtained the information will be revealed and like I said before it is relatively simple to construct.
I can tell you that it consists of four components two of which are identical. If I were to put a number on the parts needed, the two identical components have six parts not counting the nuts and bolts needed to put them together. One of the other components is six parts... again without the nuts and bolts. The last component is two parts... without the nuts and bolts. So there are fourteen main parts. The only other thing I have left out is a series of sub components in each of the main components and they are just simply common off the shelf bearing assemblies that are needed to give it all a smooth operation. Anyone with some machining ability could make it. I suppose I could offer a kit and put the proceeds from the sale of them toward helping those without the financial resources to buy one outright. Cost of materials is in the range of about a grand.
