Easier to build and understand than Marks' TPU
Started by sparks, December 20, 2007, 11:37:29 PM
sparks
   The tpu is very unique in that it isn't your typical atom smashing device but
it runs like one.  I believe the electron flow is on the skin of the collector winding.  Unlike the electrostatic generators the electrons aren't stored on a collector they are just going so fast their inertia makes them unavailable to the copper atomic structures they were kicked from.  This leaves alot of copper atoms with empty valence shells to fill.  This gives rise to a positive charge in the copper of the winding.  I believe that an electrical positive charge rises from the ordering or concentration of energy within the proton.  The neutrons are just unordered energy compared to the proton which is very concentrated energy or one could say well ordered energy. So the protons attract energy.  They can't do much with the electrons whirling  around the tpu so they go looking elswhere.  I believe a number of tpu builders have experienced this "gravity" phenomenon when the tpu really gets cooking.
       As far as the magnetic guiding shell goes.  SM says that the current flows in the opposite direction south of the equator.  I believe this is because the magnetic field enveloping the tpu is skewed differently by the
Earth's vertical magnetic field difference between the two hemispheres.
      Well it's 2008.  HAPPY NEW YEAR!
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Goat
@ Sparks & All
I've been searching all over the web trying to find clues about this box and hieroglyphics, I found what I think is the hieroglyph that Sparks mentioned at the beginning of the thread at http://www.thelibraryofhope.com/basketstories2.htm
Do a search in the document for any part of the following quote and you will see the hieroglyph which I've attached to this reply:
"The Ark itself was a small box made of acacia wood, overlaid with gold. It measured 1.15 meters long, 0.7 meters wide and 0.7 meters high. It was carried by two long bars, also made of acacia wood, also overlaid with gold. Apparently, after an ark was constructed in a university lab in the 1970s using the biblical blueprint, and after adding a fruit juice electrolyte, it was found to be too powerful an electric generator to be used safely and was quickly dismantled."
If the above is not just a rumor or speculation would it be possible to find this information and replicate it?  Minus the gold of course, unless someone here is able to get a hold of large amounts of gold foil?
I also wonder why anyone would consider this to be "too powerful an electric generator to be used safely" when in modern times we deal with high voltage transmission lines all the way up to nuclear reactors...LOL...either this is a rumor or a direct attempt at suppression of free energy  :o
Paul
sparks
  @goat
    Thanks for the picture and the time researching.  If you read the biblical account of the ark (it should be arc :)) someone got written instructions from a higher power on how to build the ark.  If the builder is like any other fabricator he isn't going to build just one of these babies,  he is going to build a bunch more and sell them to whoever he can for the highest profit.  This gives rise to a whole bunch of these boxes circulating around the mideast. What better way to control an unruly population then give your guy a blueprint to build a device that concentrated a bunch of energy and instructions on how to use it when it was time to get the crowd in order.  The ark was said to be used to seperate some river or some body of water that was in the tribes way.  If the device could manufacture gravitational fields (what I believe the tpu and cec are able to do) and this capacity diverted the flow of a river causing a body of water to expose some river bed, that would sure as hell be something worth noting.  (and it was).
       I posted somewhere this weekend on how I believe the tpu starts messing with gravity.   I need to get it up on my site but I'll state it again here.
    The electrons in the copper winding (the winding could be just a copper or gold can it doesn't have to made out of lamp wire or have a beginning or end) of the tpu are kicked off their atoms by the inductor coils which are wound from the inside of the can to the ouside.  By timing when the kick goes off there is an acceleration of these electrons and increase in their numbers which flow around and around (their journey governed by the magnetic field this flow is creating not the physical dimensions of the can). The can just acts as a scource for the electrons.  Each successive kick,  (and these kicks aren't coming every second or two they are like 1000 kicks a second) puts more electrons in the round circulation and less left in the copper of the can.  So the can starts to get real hungry for energy.  It starts to get positively charged relative to everything.  The electrons getting kicked around the can ain't stopping for anybody because their STORED KINETIC ENERGY is stronger than the can's will to suck those  electrons back into atomic orbit.   So the protons of the atoms attractor force starts to emanate into the space outside the orbiting electron field.  And this attraction is stronger than the attraction of the Earth for whatever free energy happens to be nearby.  Earth is barely holding down air.  Air is loaded with energy and pressurized air (sound waves,ultra and infra) has even more.  Enough to say that there is created an energy sceanario that is way out of wack and the only way that it will reach equilibrium is  by slowing  that frigging freight train of an electron flow down enough so that some of it's energy will go back to the can atoms.  So make the freight train energy go through an external load.  And sure enough the freight train lights up some bulbs.  But wouldn't that just amount to a flash of the bulbs and then maybe a tiny glow from the energy input of the kicker windings (this only if powered by an external scource).  That would be the case unless there is energy flow into the system from EXTERNAL SCOURCES.  What the hell besides the electron depleted can is going to attract energy?  A sine wave riding the electrical vortex getting shocked here and there?  A counter rotating magnetic field?  Maybe it is leptons or antiprotons or quarks or  leaps or desire a or b or some other shit physicists waste huge amounts of money and time observing and writing incomprehensible mathmatical formulas about so they can get next years grant money, or design a new weapon for some fuckedup military use.  What was that bomb they made a while back that killed people but left buildings intact.  Nice work boys.  Mankind gotta love you for that one.  Hope you got paid.  gonna need it to buy some  love.
Anyway I believe it is the can the collector the attractor that does the work of routing energy into the system.  Perhaps it is only a by-product of the systems configuration even then think of the power of being able to produce a gravitational field just where you want it when you want it.
Think Legacy
Spread the Love
BRAHMA
John Hutchison reconstructed the ark of the covenant and his site even has the step by step plans.
http://www.hutchisoneffect.ca/Ark%20Of%20The%20Covenant%20II.html
