Bring Electicity from H2O
Started by mxx, April 04, 2005, 03:01:18 AM
mxx
h2o2go
Not quite sure of your question? ?:-\
By adding electricity to H2O (Electrolysis) it is split into H and O ions which will form H2 and O2
This is reversable
If H and O are combined water is formed and electricity is produced (Fuel Cell)
You are welcome to visit my Website
http://home.comcast.net/~apdynamics/APD.htm
There are some examples of this process working
hartiberlin
Quote from: h2o2go on April 06, 2005, 03:28:28 PM
Not quite sure of your question   :-\
This is reversable
Hi,
interesting site you have !
You can also try KOH as electrolyte, it might be
even better than NaOH.
What is your "lab rat" ?
Is this a motor ?
On how much Watts into the latest electrolyzer
are you able now to run your car motor ?
Regards, Stefan.
h2o2go
Hi Stefan
Thanks for the good word RE: my site
I need encouragement to work on the site occasionally in stead of in the workshop? ;D
KOH would be a more efficient electrolyte but to get to 100A @ 4V I am running 3 cells in series from 12 V and tuning the electrolyte solution and electrode size to produce a 4V drop per cell.? What I use for electrolyte is not relevent as long as I can get the combination right.? If I added more cells, I may try that or H2SO4.
The "Lab Rat" is a Ford Festiva with 1300cc engine.?
The objective is to run the car on H2 generated on board via battery management process I am developing in conjunction with the H2 generation.? Success so far is teasingly close to viable, but not without lots of challenges.? I have captured a fuel delivery system from a Propane powered forklift engine of about the same size and am modifying for H2.? This should bring me some quantim of efficiency ???
Watts: I guess the answer is, 12V X 100A = 1200W which is maybe 1.5 HP which is probably what it takes to run the engine at a poor idle? ::)
THANX
Dave
hartiberlin
I see, thanks for the info.
Well, maybe try to run the H2 + O2 mix with air in a ratio of about
30:1    air: H2 +O2
This means much more air than oxyhydrogen gas !
Then you also get a slower bruning of the gas and
it will not damage your cylinders due to detonation.
ALso you have to change the sparking timing of the sparkplugs
to get the right timing of the spark occurence at the right shortly
after TDC...
Good luck and please keep us informed about your progress.
Regards, Stefan.
