Bring Electicity from H2O
Started by mxx, April 04, 2005, 03:01:18 AM
0 Members and 59 Guests are viewing this topic.
jpete
what kind of electrodes are you using
what are they made of
and the dementions
rlm555339
Quote from: jpete on April 19, 2005, 10:49:40 PM
and the dementions
If this question is directed to me, all my info and photos are on the other thread in this category called Ronald Classen's H20 Motor Project.
Ronald Classen, 30+ years electrical tech
psyd
Try this ..
Use platinum / indium plates and use an amount of a formulae that I have developed as the electrolyte.
Gas generated is in the order of 4 times previosly encountered using H2O alone.
Getting the mixture right in the engine may require electronic control similiar to Auto fuel management systems.
Your thoughts.
rlm555339
I'll check into that platinum / indium............so far I have only used tap water.  Tonight I added a little baking soda and started tripping my auto-breaker so I'll have to get a larger value, I suppose.
I can produce between 0.7 and 0.9 liter of gas a minute depending on how much electrolyte I use.  The 0.7 figure is just from plain tap water at 40 amps  It's not enough.
You have a formula?
psyd
yes I do , but like all things this was years of research to discover.
But boy does it increase the ratios of gas produced to unit of energy taken up in it,s production...
this then will lead to a system that will only use a smaller amount of its generator output to produce an excess of gas that will make over an over all system that free runs " under it,s own steam".
By the way the voltages I have used successfully are as previous writers have stated only < 12 volts D.C.
