Muller Dynamo
starcruiser
Thoughts;
Inductance is increased in the coils by using a Ferrite core of some type (Magnetite etc...)
Multi-stranded, isolated (magnet or litz wire) strands. At least 7 strands in parallel to provide less resistance and more voltage. (Skin effect?)
Back EMF is utilized on the generator side by using FWBR to capture all output
Magnets are used to increase flux strength in the coils and cores.
Magnet strength is adjusted by inserting spacers
Magnets field is adjusted by offsetting its location on the coil seat (focusing the field?), is this needed because of how the field is propagated from the NEO mag material? inconsistency in manufacture?
He mentioned that he inserted ferrite magnets, did this smooth the field, i.e. refocus it?
Ferrite cores are selected due to B/H curve and magnets bias the ferrite into the knee area for best response?
Large capacitor is used for capture/conversion of generator output.
regulator is used to isolate the generator form the drive section.
It is kind of a summary and some stuff that may need confirmation thru experimentation. Just wanting to summarize some of the key points as I see them.
Regards,
Carl
caccr2000
para descargar videos o cualquier archivo sin tener problemas de corte usen este programa
http://www.jdownloader.org/download/index
Tudi
@Dbowling : Interesting. Now why did romerouk say that it might take a month to finetune the device ? Maybe there is a distance when he observed this lockdown effect ? Depending on the power usage he did mention you will need to finetune it. This power usage drains the coil thus removing the lockdown effect, or not ?
Dbowling
I've tried "sparking" the magnet again, but that does not release it. I didn't try draining the coil with a load, nor was I able to spin a magnet past the other end of the coil as RomeroUK would have done. All I was trying to point out here is that there may be something unexplained by our modern notions of how electricity and magnetism work and/or affect each other that RomeroUK came to understand which makes something that shouldn't be COP>1 actually work. And that it MAY be the magnet on the coil. Don't discount it just because it seems to be such a simple thing. It has effects that are not "normal" by current laws of electricity and magnetism.
powercat
At about one minute 47 seconds into the video  the rotor can be seen rocking When the battery is connected,/ before looping.
http://www.youtube.com/watch?v=o3YqCp84IOE&feature=channel_video_title
Is there a way to measure this by video analysis ?  distance of the rocking and timing of rocking
This could be matched in replications ?
