Muller Dynamo
0 Members and 37 Guests are viewing this topic.
Pirate88179
Quote from: AbbaRue on May 19, 2011, 11:04:19 PM
I wanted to make a quick point here.
I used to work for a sign company and was told by the owner that Lexan is so dense that it can stop a .22 bullet.
Because of the high speeds involved with this motor, might I suggest builders buy a sheet of Lexan and
place it loosely around the outside of the unit.
This way you can still watch the machine run and the Lexan may save your life if a part of the machine flies off.
Please note that for Lexan to be bullet proof it needs to be a minumum of 1.250" thick.
http://k-mac-plastics.com/bullet-proof-acrylic.htm
Very expensive too.  The above link shows many materials based on Lexan.  The thinner sheets we can afford are liable to shatter and release shards/shrapnel and the neos will most likely shatter as well.  I lost a neo from a rotor at about 10,000 rpm, it was not pretty.
I am not sure how thick a sheet we would need for an effective guard for the flying neos, but I think it would need to be more than 3/4".
Dave45
Quote from: happyfunball on May 20, 2011, 01:32:52 AM
Um...
Does anyone find it strange that the 'updated' Mulller device shown on http://mullerpower.com/index2.php links to a pitifully bad testing video of testing said device? I highly doubt their updated generator is OU, and it was done by his daughter, will full access to her father's plans patents and insights. What could Romero know that they don't?
Not sure if he knew or just stumbled onto the answer in Mullers design the magnetic field rotates with the gen but in Ramero's design you have two rotating fields like in Walter Russel's diagrams.
David70
Today, after many attempts to call to speak to Romero he finally answered me.
First he said that I should not reposted the picture he removed previously but didn't say why.
Now about the muller setup:
Very important is that at voltage lower than 6 volts the device worked for a while then slowly looses rpm, with or without load. He also mentioned that the generator has a low and a high limit in rpm where it behaves good. He said that muller replication started few years back but only recently after learning and understanding more tricks he went back to it and tried to improve it.
When I asked him about the secret in his design he said that even himself could not understand it all. The person that scared him reffered to this Muller design only and didn't care about other type of devices he might build in the future, but not this design. Why???
He also asked me not to call again.
Now, I don't know what to say is it real or not?
LtBolo
Quote from: David70 on May 20, 2011, 09:41:28 AM
Because it worked...
lanenal
Thanks for sharing. If Romero said he understood it all I would immediately say that's a lie. He learned more tricks, put them together, and it worked, but he might never understood why! Humans are having xes (read it backwards) for all history, but who can understand exactly why? Sure there are theories, but how do you know which one is correct?
