Muller Dynamo
Hope
Hi all,
Just reviewed a Tom Bearden certified "WORKING" motor that was taken from the world   here is the concept (working)  we should just use a timing wheel and log rhythm in a chip controlling delay or advance firing to keep tuned as speed increases.
Shadesz
Hey guys! I thought you may want to consider this connection I made. Here is the link...
http://www.energeticforum.com/157895-post1765.html
And here is a text copy for backup...
QuoteSo tonight as I am laying in bed I realized something you guys probably already know. But for those who haven't made the connection yet I figured I will post it.
I was laying there trying to go to sleep and it 'clicked'. I finally understand what we are trying to do when we delay lenz and what we need to focus on to do so.
Essentially, when we are trying to delay lenz what are we really trying to do?
Well we know that lenz law says that if we induce a current in a coil of wire, the coil of wire will create a magnetic field that is opposite our initial force. So what does that mean? That means this...
Say you have a south face side of a magnet approaching and leaving a coil as Rod does in his setup. This motion will create two currents in the coil wire. One current as it approaches the coil and another current as it retreats from the coil. (This is basic stuff)
Now lets take it step deeper...
Remember, our magnet face S is approaching the coil. The current that we produce in the coil is in such a direction that the side of the coil facing the magnet is now also a South pole. These two poles push against each other and what does that cause? Lenz law.
Now we switch direction and your magnet starts to leave the coil. As your magnet leaves the coil it creates a current in the coil wire in the opposite direction. This then creates a North pole on the coil side facing the S face of the magnet. This creates an attraction force and what do we have again? Lenz law.
So now we can see that lenz shows up twice per cycle. Once on approach (as a repulsive force) and once on retreat (as an attractive force)
Ok, still kinda basic level stuff, but maybe that's all we need....
What do we need to do to get Lenz to work with/for us?...
Ideally, if we delay lenz by just over half a cycle we get a driving force. Why? Because when lenz finally creates the S pole on the coil face, the magnet will already be on its way away from the coil, hence we get propulsion. Make sense so far? It does to me. But it gets more exciting!...
Is this possible? YES!
What is this called? Phase shifting!
Does phase shifting happen? YES!
Where? In transformers.
How do pulse generators relate to Transformers? They ARE transformers! The primary coil isn't a coil though, it's your rotor magnet. The secondary coil is a coil; you know it as your generator coil. Again, the primary coil is your rotor magnet, the secondary coil is your generator coil.
Now when we phase shift our 'transformers' just right, that phase shift can potentially DRIVE our transformers!
Here, check out this quick video to get the image in your head before you read on...
Phase shift differences under variable loads. - YouTube
Did the video make sense? Did you catch the cool part at the end? It explains why we are seeing acceleration with coil shorting! From 1:15 he explains...
"Depending on the size of load will determine how big of a phase shift there is.  I am going to hook it up to a load with even less resistance here. ...??... Ok, I hooked it up to an even bigger load this time. So [now] you can see how the phase shift is even more pronounced when you have a bigger load on the secondary side of the transformer. [which in are case means the generator coil]"
This not only tells us that we can achieve a lenz driven dynamo (or at least lenz assisted), it tells us that we can control the speed of it to a certain extent!
Freaking cool if you ask me! Note: this also may explain those generators that were seeing more acceleration under a medium load than a full short. Their particular phase shift timing required a resistance that was a little higher than a shorted coil. Perhaps their shorted coil produced a phase shift that was too pronounced, and a less dramatic phase shift is what their design needed? More testing needed, but I feel this concept can help us focus on the right question...
How can we maximize and/or gain better control of phase shifting?
I haven't studied phase shifting yet so I have some basic questions. Do any applications encourage phase shifting? If so, what are they? How do they do it? How can we replicate the effect? Personally I think these questions are going to be the key to these generators going OU.
We already know one way, and that is to decrease the cycle time by increasing the RPM. IMO this would also explain why Romero says this...
QuoteMariuscivic and toranarod  are close enough.Both will have to concentrate to get the effect at lower speed. After a certain rpm you will have no gain then again at the next step will have again and so on...
Example: if starting the effect at 1000 rpm then the gain is going to vanish at 1600rpm then we can get it again starting at 2000rpm... at one point in every cycle voltage drops down even if the rpm is going high.We are getting multiple resonance points and not all are the seme, some are better than others. This is only one example, don't take for real and start looking to have 1000rpm...
Now I am not looking to get the speedup too much, I want the rpm to stay stable at any load or short. I am going to have it confirmed when I will finish my new generator, towards the end of this month.
Romero
[/URL]
The multiple resonance points may be explained by a static phase delay in our core/coil coming in and out of optimum phase shifts due to our changing the cycle time (RPM). Pretty cool! Although if this is the case, I don't see him getting a constant RPM with varying loads.
So the question remains... What other ways can we maximize and/or control phase shifting? What ways can we do it that won't require us to change the RPM? :thinking:
Man I wont be able to sleep for a while now! lol
Disclaimer: The above principles and concepts are released open source to the world free of charge by David Sphar on Sept 19, 2011. Please make a copy of this post as a backup record of this release. (Just in case the idea actually proves to work and the $$ folks try to steal it)
DeepCut
@ Hope,
what is the device, that picture doesn't tell us very much ?
From other Planet
i had a thought today...
if tito is right (dont want to discuss his credibility here!), and many famous solid state (bearden,bedini, kapanadze, muller) devices work tesla radiant energy collecting like(think of any coils used as the secondary=long one of tesla coil), perhaps we can improve the efficiency of our zpe tapping generator coils easily somehow.
Perhaps with a long wire connection to ground on one side, and long wire with isolated metall sphere at end on other side, like Tesla use in some devices. Like boosting Muller/Romerogenerator  ;D
But could bring RF Problems.
Just a thought, i didnt try it yet, but i will these days
Sorry for bad english^^
baroutologos
The wild goose hunt goes on... amusing at least.
On the bottom line, nice to tinker ,expensive though.
