0 Members and 18 Guests are viewing this topic.
CLaNZeR
ummm just realised I layed up the stators as per jdo's cad drawing, but I think it may be wrong.
Cheers
Sean.
http://www.overunity.org.uk
RunningBare
Quote from: Omnibus on January 25, 2008, 09:13:40 AM
After stopping the two stators measuring the AGW stator he indeed says ?almost 5000rpm? but the tachometer measuring the AGW stator reads 4131rpm.
Not only the measurement seen in the video is messy but at no point measurement of the rotor rpm seems to occur.
Are you so sure it's not 4731 RPM?
Omnibus
Like I said, the measurement in @alsetalokin's first video is messy and no advocacy can save it.
Bruce_TPU
Quote from: CLaNZeR on January 25, 2008, 09:20:19 AM
Well as close as I can get to the original Rig for the Wind Down tests.
Got to shoot out now, but will fire her up later and post the results.
Cheers
Sean.
Thanks Sean, looking forward to it.  I think it will be different, using the alloy over the pure Aluminum.  We will see.  ;)
Cheers,
Bruce
Omnibus
@CLaNZeR,
Seems to me not only the dampers have to be around the stator equidistant from the other two stators but the first video shows that one of the dampers is closer to the stator than the other damper, not as in the picture you showed here.
