ken_nyus
Quote from: Bruce_TPU on February 06, 2008, 10:10:47 PM
Correct -
I need to use a 3/4" long 4/40 Stainless Steel (interesting) screw.  I need a tiny Stainless Steel washer for under the bearing to hold the center race and act as a spacer for the bearing.
Small progress is good!
Cheers,
Bruce
Bruce,
The place I found these screws is:
http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=1607
I went with 1/2 inch myself.
NT55-186   1   $9.00      $9.00      50/PK SHCS- #4-40 x 1/2
ken_nyus
Quote from: vipond50 on February 06, 2008, 09:45:42 PM
Now.... The mass of the HDPE Plug...
My recollection was the rotor plug was Delrin.
Bruce_TPU
@ Bill
Of course!   ;)
@ Ken
Thanks!  What does the SHCS stand for?
AndreaGanora
Incorrect -
I am not using Stewart-Warner Bearings for my Stators
Correct -
Order Stewart-Warner bearings of correct size from Mike, the bearing guy.
Cheers,
Bruce
@Bruce
I don't remember Al writing anyting about the Stewart-Warners beyng for shure the ones that worked properly as stator's bearing between the 13 he had, since he had some Stewart-Warners , but not enough of them , so he bought some other unlabelled ones . so is a good start knowing the maker of some of them but isn't shure they are the good working ones , at least not that I remember him mentioning  it .
just a notice  ;)
keep the great work up
P.S. edited
here is A dimensioned sketch of the design for the stator magnet/bearing holders made by AL :
ken_nyus
Quote from: Bruce_TPU on February 06, 2008, 10:35:32 PM
@ Ken
Socket Head Cap Screw. You will need an Allen wrench for them.
Also remember Al ground/cut down the heads, "for clearance".
This is the one part of the rig that I have played at putting together, and even clamped down it is a pretty loose setup, with the little washer underneath, and just the bearings trying to hold things straight.
