0 Members and 79 Guests are viewing this topic.
jcims
Quote from: LarryC on January 16, 2008, 05:01:42 PM
@m0thman,
Same situation here, this is more stressful than watching LSU football this season.
Try being a buckeye fan sometime...lol
MeggerMan
Hi Bill,
I sort of recognise your handle from the Joe Cell days, did you have a running Joe Cell in your car at some stage?
Hi Jason,
Very sorry, I have to disagree about placing a stronger magnet further away.  If the attack angle between the rotor and stator are critical then it may be that N35 are just right and that N42 or above are just too powerful.
http://www.athenapolis.com/NN_MotorintheMagnet.htm
http://www.athenapolis.com/NN_FindingtheMotor.htm
According to the tests that Nick Nelson has done: "each pole of a magnet consists of 3 or 4 separate and distinct magnetic spin zones,depending on the pole".
So if the motor is reliant on these spin zones then getting the magnet of the correct strength and dimension may turn out to be critical.
I am even wondering if the stator would benefit from a slanted angle to the rotor (45 deg. in both planes).
I am keen to try out his ring magnet idea to see if will rotate by hand then try and make up a simple spindle to allow it to rotate on its own.
If this idea turns out to hold water then it certainly opens up a whole raft of possibilities for the WhipMag and the TPU.
The science of magnetic spin zones, sounds catchy.   :)
Rob
sterlinga
Quote from: hydrocontrol on January 15, 2008, 08:47:09 PM
Finally got some shop time. I know it is not an exact replication. [...]. I also found it spins better one direction (CCW) then the other (CW). Not sure why.. Lots of playing to do before I get more shop time. At least it is a start..
I posted a feature page on this:
It would be nice if we had more info
- how fast did it run?
- how long?
- did it accellerate
- video
Thanks
Sterling
http://freeenergynews.com and http://peswiki.com
"The best cutting-edge, clean energy news and directory service on the net."
Rosphere
Quote from: btentzer on January 16, 2008, 04:20:02 PM
Quote from: blue_energy on January 16, 2008, 01:24:36 PM
QuoteSince Alsetalokin mentioned that exact distance of the stator magnet to the rotor is quite important, I wonder how important slight differences between the individual rotor magnets strenghts are.
But how to determine the differences in the strength between the used rotor magnets?
Well, if you have more magnets on hand than the number that you plan to use and you want to select a smaller group with the least amount of difference between them, then I suggest using a compass in a manner similar to the way that I used one below.
These are 1/2" 'Home Depot' disc magnets.  The compass would normally point vertical, towards the top of the images.  The North face of all magnets point towards the compass.
One lone magnet at the bottom, (not pictured,) will balance the Earths field at about 4_25/32", center-to-center.  When the compass points East, or West, all the North fields are in balance, (remembering the Earths constant 1T from the top.)
As expected, the strength doubles with ever smaller increments moving towards the magnet.  At 4T I had a hard time preventing the influence of the compass needle from rotating the magnet.
All magnets are freely resting on the surface.  The black paper-tape is there just to keep them from rolling away before I could snap a photo.
http://www.overunity.com/index.php/topic,1872.msg33963.html#msg33963
There is no need to go to all that trouble.  All you need to do is slowly approach the compass directly from the South with the North attracting side of the magnet until the compass starts to spin towards the magnet.  Back it off even slower until the compass needle is 90 degrees, (pointing East or West,) and mark the position of the magnet.  Repeat for all magnets and select the number that you need that have the least amount of deviation from each other.  Good luck.
Anyone trying this suggested method, please let me know if it is useful, or not.  Thank you.
(NOTE: If you are extremely anal retentive, then you can check both sides of each magnet by also approaching the compass directly from the North with the South attracting side of the magnet.  I wonder if this will always turn out to be redundant.)
sterlinga
Quote from: Omnibus on January 16, 2008, 04:29:48 PM
@All,
I want to report that the initial experiments are very promising. After the initial spin a definite acceleration is observed which so far still cannot be sustained as long as @alsetalonkin's but the effect is definitely there. I will restrain at this point from posting a video or quantitative results which I will present to you later.
Posted a feature page here:
Photo, video, additional info would be nice, so I could feature this in my news.
