Thanks to ALL for your help!!
Gravity Motors = Free Energy
Started by Michel, July 16, 2005, 12:45:50 PM
_GonZo_
I can see by the links that they have put really big efforts in this nice desings:
In order to understand how this machine is suposse to work let me see if I can simplify it.
Imagine a heavy ball (pool ball for example) in a empty water glass, cover the glass with rubber (a piece of a balloon for example) when the glass is upwards the ball is in bottom of the glass and the rubber cover is flat.
When you turn the glass downwards the ball will be pressing the rubber down and the ruber will not be flat, it will be pushed a little out because of the weight of the ball.
All OK up to here.
Now make two of those or more and attach them to a axel one in oposite to the other (one glass upwards and the other downwards) and introduce it in water.
The rubber in the glass that is upwards will be press down into the glass due water press.
The rubber in the glass that is downwards has press fron the water as well but has the ball pressing the rubber down so the deformation in that rubber should be lees than the other, that may means that the volume of this glass is bigger than the glass that is upwards.
Due Archimdes principle the glass that has more volume will be pushed up with stronger force than the one with less volume and will move...
Will work or will not? make calculations...
Let me some minutes and I will make an schema of the siplifyed machine.
_GonZo_
_GonZo_
Make the calculations againg there is some thing really wrong.
