Thane Heins Perepiteia.
0 Members and 55 Guests are viewing this topic.
i_ron
Quote from: woopy on February 27, 2009, 04:29:37 PM
@all
as a junior member i have surely not the immense experience of the senior 's one
but  i like  new thing  i like new oportunities   and i am inclined to believe that we can improve our human beeing
@ wattsup
if you think that Thane is simply a faker  why do you  insist to get the PROOF  simply change the frequency to other threads on this forum    and as you said yourself very correctly " after  all this is his thread"
let Thane go on his very particular way to communicate  .
all the best to all
laurent
Words of wisdom from the junior member!  Words that some of the senior members missed.
Yes Laurent, you are right, for it to be a better world then we have to be more forgiving of other
peoples idiosyncrasies, especially if the sole complaint is, "I wouldn't have done it that way"
Take Care,
I'm Ron
edit: after talking it over with other senior members it was decided to give the poor guy another chance. But let it be understood if there are any future complaints to the committee, we will say
to Hull with it and he shall be put in a weighted sack and dropped in the river!
[for people in far away lands, more "in" humor... Hull is right across the river from Ottawa. Next to
the parliament buildings is a bridge, when the wife and I where there we walked out on the bridge
and the view of the parliament buildings and Hull is spectacular!!!]
http://urbantoronto.ca/showthread.php?t=5563
markzpeiverson
Quote from: hydrocontrol on February 27, 2009, 05:29:59 PM
I do believe that Thane was purposely staying away from the OU claim and leaving that to others to make or confirm by replication. Why ?  Just look at others on this forum that have claimed OU or possible OU or even an idea for OU.  See how they get torn into pieces by armchair observers. Just like wolves circling the sheep. I do not blame Thane for staying away from any such OU claim.
What Thane is claiming is an improvement in efficiency.  This is significant. Take your typical gas power generator. It can produce around 4400 watts using a 6.5 HP engine. Now what if you can improve that generator so it can produce 4400 watts using a 1 hp weed eater engine. You are now talking about using a lot less gasoline to produce the same amount of energy. See it does not have to be OU to be very beneficial. All it needs to do is increase efficiency so it requires less of one form of energy to generate another form of energy. I believe that is all Thane is claiming and showing in his videos.
It's even more fundamental than that...
What Thane seems to have shown is that a fundamental law of electrodynamics involving generators under load, namely Lenz's Law or BEMF, is NOT an inevitable negative to the system.  It can be either reduced/eliminated, or 'rerouted', so that it is, at the very least, not a drag on the prime mover (motor), and perhaps can even be put to positive use.
When you consider the single fact that Lenz's Law is not as simple (and always negative) as taught in ALL text books, then it opens a whole can of worms as to how to utilize it for new and novel devices... couple that new knowledge with human creativity and sound engineering, and you have entire new industries being created.  If what appears to be true here, is true, this will have a very profound (positive) impact on the power generation industry.
Powerful sh*t, man!
PS:@wattsup, if you'd look at a number of the videos, you'll see that Thane has used an AC analyzer on many occasions.  This instrument shows input voltage, current, PF (power factor), and watts. Since you fail to mention PF as a requirement for your desire to see power in, power out data, perhaps you should do a little more homework before jumping down Thanes throat...
-Mark
We dance round in a ring,
And suppose...
But the Secret Sits in the middle,
And knows.    --R.Frost
CRANKYpants
Quote from: wattsup on February 27, 2009, 09:05:15 AM
@CP
Therefore, I formally ask you to remove the following post immediately until such time as you have satisfied this Forum's due diligence. And even then, you will have to get Stefans' further permission to post such a "commercial position" on this open source Forum.
http://www.overunity.com/index.php?topic=4047.msg157984#msg157984
THAT'S SICK!
T
CRANKYpants
Quote from: markzpeiverson on February 27, 2009, 07:01:39 PM
- Mark
GIVE ME A BREAK PLEASE MARK  ???
THERE AIN'T NO WAY IN HELL - WATTSUP IS GOING DOWN MY THROAT!  :P
THAT'S JUST SICK!
T
CRANKYpants
Quote from: i_ron on February 27, 2009, 06:14:02 PM
HEY!
SEE THE MUSEUM OF CIVILIZATION IN YOUR PICTURE?
I USED TO BE THE EXECUTIVE CHEF THERE...
UNTIL I GOT FIRED.
T
