Tesla Resonance
Started by allcanadian, February 04, 2008, 06:09:41 PM
allcanadian
At the following link ---- http://www.eskimo.com/~billb/tesla/biog.txt ---- Tesla describes how as a child he and some friends rolled small snowballs down a moutainside and one had reached the size of a house which facinated him that so feeble an action could lead to an avalanche of energy. He also mentioned that like so many people we take the power of observation for granted. So lets explore the simple snowball effect, I find it very interesting that physics has no description for Teslas snowball   we can describe the work performed (F x D) when a snowball is dropped or rolls down a gradient --- the vertical drop is distance and gravity the force, but there is no calculation, no equation that describes the inherent qualities or properties needed to produce a magnification of force and energy as in the case of the snowball. In the case of the snowball we could say it does nothing other than start a reaction, what is most important in this case is the qualities of the media involved, that is the snow must be sticky enough to adhere and fluffy enough to pack as the snowball rolls to withstand centrifugal forces trying to tear it apart. So we can say the qualities and conditions must be "perfect" to produce this "snowball" effect, we could also say the initial energy input has literally no bearing on the resultant energy output. I think this avalanche effect in electrical terms must be resonance with external forces, I have seen resonance in action and can tell you it is pretty wild. I used a 1.5v battery and rheostat to power a micro toothbrush motor on a two foot long 1/8th inch metal rod attached to a vice on my bench. A super small vibration leading to a larger one in the rod and my 3' x 8' bench was making a loud noise and all my tools were moving all over the place, small nuts and bolts dancing 1/16th inch off the bench. Physics cannot explain this, take all the energy involved in the movement and noise in this example and compare that to the few milliamps needed to produce it and it becomes pretty obvious something is out of place.
In any case I found the link above a pretty intersting read  :)
allcanadian
I wonder if Tesla left us a clue in regards to his snowball scenario in my last post? Did you make the connection? I was a little slow on the draw as usual, it took me 20 minutes of analogies to get this.
We have a snowball which physics says will perform work in a gradient ( the mountain side )based on----, Work = Force x Distance, the Force being (Mass x acceleration) the acceleration is gravity. But physics has never considered the "snowball" effect or "avalanche" effect as it relates to nature, when qualities and conditions are correct the snowball will gain a massive amount of energy based on a gain in MASS, acceleration due to gravity is constant, it supplies the energy to the ever growing mass of snow. The "connection" is resonance, consider a mass (tuning fork) that is vibrating, it could be considered a single entity until many resonant tuning forks are brought close to it. At that point all the tuning forks could be considered as acting in unison, they could also be considered as a very much larger MASS vibrating at the same rate---all as one--- all reinforcing one another. The "resonant" system has gained MASS in motion and in doing so the force has increased as well as the ability to do work. The original tuning fork does not need to furnish all the energy so we could say resonance is a magnifying effect but it depends on the "amount" of mass in resonance. The qualities and conditions of each individual mass determine how close to pure resonance each element is in respect to the whole--- the greater mass in resonance acting as one.
Yet another reason why Tesla ROCKS!!
armagdn03
at this rate, someone is going to have a free energy device in no time.
I wish I could turn my brain off sometimes, then I could get some sleep.
jeanna
And so a skater starts a spin. The arms are out then he begins to pull them in and spins faster and faster as the arms get closer to the center.
And so Tesla's coils taper and the radius gets smaller and smaller the speed of the frequency gets higher and higher as it approaches the top.
And a tornado / torsion field is always more powerful at the narrower end....
And a sine wave in 3 dimensions gets rounder and fatter then narrower and finally gets to a point in time (a 4th dimension) then begins again
wild thoughts, sorry for the intrusion.  :D
Ren
Awesome analogy AC! There you go again, making me think :o :D
