Peter Davey Heater
Started by storre, February 09, 2008, 11:00:32 AM
DOCV
Can anyone check these calculations, notsure if correct.
To heat 1.5 ltr of water from 14 deg celcius to 80 deg, theoretically should take 0.1151 Kw/h
Calculated as such:
(80-14)x1500=99000 cal
99000x4.2=415800 joules
415800/3600000= 0.1151 kh/h
So I tool my kettle and hooked it up to some metres and got the follwoing:
1.5 ltr from 14 deg to 80 deg in 261 sec with a voltage of 220 and a constant Amperage of 3.57
Therefore 220v x 3.57A = 785.4 watt sec
785.4 divide by 1000 = .7854 Kw sec
0.7854 divide by 3600 and x 261 = 0.0569 Kw/Hr
Divide the theoretical of 0.1151 and 0.0569 = 2.02
I can't believe my standard kettle has a COP over 2.
Where is my mistake ???
nul-points
hi DOCV
...listen carefully because i'm only going to say this once....
SELL EVERYTHING YOU OWN & BUY SHARES IN YOUR KETTLE MANUFACTURER RIGHT NOW!!!!   ;D
...seriously, now, i think perhaps your current reading is wrong - 0.785KW seems a very low-powered kettle (mine is rated at approx. 2KW at 240V, so it would draw about 8.3A)
all the best
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
NerzhDishual
Hi guys,
I believe that this bell shaped things dived into water and 220 Volts AC wired
have a very strange behavior.
Why, when put on the water this way:
my 10 amps fuse blow out (in about 20-30 seconds) and do not blow out when put this way:
BTW : the COP is statistically the same.....
Else: you logically could think that any metallic piece(s) plunged into water and AC (Or DC) 'fed ' could heat this water with a COP that can be compared to a kettle COP. (about 0.9 - 0.95)... That seems not be true:  ???
More to come ASAP
Best
Nolite mittere margaritas ante porcos.
DOCV
Quote from: nul-points on June 13, 2008, 01:16:20 PM
hi DOCV
all the best
sandy
If there is anything wrong you are probably right about the amps. I will go tripple check .... then I am going to sell everything and buy their shares.
satchid
Dear All,
I am new at this heater forum an have been reading as much as I could find about this bell heater.
I have a question that sticks out high above the others to my opinion:
What makes the bell resonate? There is almost no current between the input wires. therefore is it supposed to resonate on the voltage alone? as a capacitor maybe?
Or is there a special resonator placed between the 2 bells that receives the 220V to vibrate the one bell at 1600Hz and the other maybe as well, and If the 1600Hz is a good frequensie to make the molecules in the water rub against each other rather violently, then there could be a solution.
Thanks for the good forums.
Willy
