Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
synchro1
Attaching a flyback diode to the end of a stack of Neo magnets and sparking reverse current through them back to the positive of the power source will measure gain. This is the Nazi UFO secret.
Power has been curtailed to over half a million customers in Northern California while this kind of suppressed technology remains on the shelf.
synchro1
Here's a comparison of a spark with ring magnets and one without at the same power setting:
synchro1
What would happen if we attached one end of a diode to the electrode of a capacitor and the other end to the correct pole of a Neo magnet; Then discharged the capacitor by sparking a wire from the other electrode through the strong Neo magnet back into the capacitor? Which way would the voltage go in the capacitor, up or down?
Would the demonstration of a positive voltage gain signal a "Black Friday" for the stock market?
Suppose we ran a clip wire through the hole in a tall stack of Neo ring magnets, facing the right way, then discharged the capacitor through the wire into itself by sparking through a diode from the other electrode? Would the BEMF increase?
Would a demonstration of this kind of overunity gain trigger a Wall Street crash?
It occurred to me that all one would need to do is run the loop diode wire through the hole in a stack of right facing Neo rings from my three pole SPDT pressure switch to go OU. It's Unity with out these BEMF amplifying magnets already. That should put that masking pulse oscillator over the top.
The COP of a single pulse would equal the COP of the GAP oscillator. A sandwiched maze of ring magnets on the loop diode wire would deliver the same increase of gain either way.
The Neo rings would go around the top wire and return to the positive electrode through the diode:
sm0ky2
I would like to see side-by side scope shots of the output.
Perhaps an HV probe
I would assume there is a time delay on the signal w/ the magnet
As the same power levels would take longer to induce through the
magnetic field.
If the input were not restricted (kept constant), the magnet would
cause more current to be drawn from source.
synchro1
Quote from: sm0ky2 on November 30, 2019, 09:57:20 PM
Perhaps an HV probe
magnetic field.
SmOky2,
The capacitor would need to begin with the same number of Joules charge each time for the comparison test. Do you have an oscilloscope?
The only power amplified by the magnet is from the interruption of a spark. The end of the spark hits the ether gas like a hammer in direct proportion to the power. This shock polarizes the dielectric field. A radiant spike separates from the magnetic in the instant of a spark collapse that cannot pass through the conductor, but can transit the Neo magnet field. The radiant spike accelerates faster then the reverse magnetic current around the conductor and helps speed it forward in it's wake from behind. This should resemble a "Slinky catch up" kind of scope signal.
The power would take longer to induce through the magnets if they were facing in the wrong direction; Reversed, they have an opposite effect. (To reverse "Wave Polarized" current from spark collapse)
