Liquid hho
Started by troyd1, February 23, 2008, 07:21:55 AM
troyd1
I was brainstorming and was wondering what would happen if you put hho under pressure. Would you get a tank of liquid hho similar to propane or would it combine into water? Any thoughts? I have ever seen this discussed and thought it might lead to something valuable.
WyTTraven
unless you separated the hho into one tank of hydrogen and one tank of oxygen you would simply have a tank of pressurized water. the hho would recombine back to h2o
armagdn03
I try to drink at least 8 glasses of liquid HHO a day.  ;D
I wish I could turn my brain off sometimes, then I could get some sleep.
IronHead
Hydrogen does not turn to liquid under pressure . The highest pressure tanks I have seen to date is 180,000 psi where hydrogen is still a gas. The only way to get hydrogen into a liquid state is to remove the heat.
mscoffman
Browns gas, that is, an uncombusted mix of hydrogen and oxygen gas in stoichiometric proportions
has a dieseling pressure of only 400lbs psi at room temperature I think...So stand back.
