Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
bolt
QuoteThe flow may not be normal, but it should be related to electrons if we are dealing with solid state conductors.
im not sure they are identical but they still pass through wires caps and coils. You fly a kite during a thunder storm chances are it will be hit by lightning and will lead straight back down to earth if the kite flies on copper wire. The energy only exist while the static charge is making up for the depletion of charge on the negative side for the time it takes to equalize the depletion. I don't know how one would calculate this but i bet the energy required to create the thunderstorm power is insignificant to the energy released when the PD decides its enough to bring itself back to parity which clearly is in the thousands mega watts range. This is natures OU device. In other words the storm clouds are the catalysts so to speak there is NOT megawatts floating inside of that cloud par se.
People of said for many years we only need to harness the power of lightning to power a city. Tesla knew and did this all those years ago. He realized the real power was NOT in the clouds but occurs when the charge is moving rapidly to cover the depletion. Therefore all one has to do is create a constant depletion and pull the static charges apart and the power will flow. It only takes voltage of this type to create the depletion. Bearden says the same. If you create a dipole you have all the energy you even wanted but ONLY if you do not allow the dipole to collapse.
aleks
Quote from: bolt on March 22, 2008, 12:17:43 PMPeople of said for many years we only need to harness the power of lightning to power a city.
The static charge does not like to be scattered around. How can you tap the charge if it's only contained in a cloud? Telsa was a genious no doubt, but even genious changes his mind from time to time. Of course, I understand what you are trying to say, but in order to create depletion you should invest energy. Why do you think this depletion will be filled with a lot more energy than you've invested? Can you create waves on the water if you slap it with your hand of energy higher than what you put into slapping? Well, some guys happen to be able to get more heat from water with their chess-order drilled rotors, but they are doing nothing more than creating implosions (collapsing cavities). This is another example of excess energy not related to earth's magnetic field. I've collected a lot of evidences where implosions produce excessive energy: ranging from atomic bomb to spark gap.
bolt
SM told you to pay attention to this fact im am describing. When you realize you are not dealing with conventional electron flow or certainly not the generation part of it anyway but in laymens terms its a lightning generator.
"Now about the DC output with AC signal.
There is a book about Nicola Tesla "The Man who Had lightning in his
hand".
I suggest that you find a copy of that book and read it.
In that book it is related that Tesla states that you can have all
kinds of electrons flowing through a wire traveling in different
directions relating only to their potential power source.
He even said that you could have different electron flows through
a single wire completely separate from each other.
I tried it and he is right!
bolt
Alecs the lightning charge is the closest that most people can associate with this type of technology. Im not suggesting the charge is in a cloud and that the only place it exist but it does exist there during a storm as well as anywhere else.
"but in order to create depletion you should invest energy."
No not this energy this is the basis of all the OU devices.  When its done correctly the amount of energy required to create a depletion is nothing compared to the resultantly energy that come back for the correction. Im not saying this is the only type of non conventional electron flow either. Thrapp says there is over over 20 forms.
In the motor guise like the Edin Gray motor his invention produces a depletion of charge which is split into caps and stored. When these charges try to equalize the amount of power is massive on the rebound which is used to power the coils to provide the magnetic field to drive his motor. Likewise with Newman's big motor on yourtube his little stack of 9 volt batteries only provide for the depletion of the static charge biased to another. The resultant energy that comes after to correct this imbalance is massive and its this that is used to power the motor coils and to produce the magnetic force NOT the pp3 batteries. You can see a small magnet dangling on string spinning around on the workshop wall some 10 ft way from the motor to give an idea of the field thats generated.
It only take volts not current to make depletion but the result is volts with amps coming back.
wattsup
@comp-tech
Compiling quotes is a dime a dozen. And this is only your second post with such a long nothing. If you want to really be useful and sincere, go back to the threads where these quotes originated and understand the discussions that were in progress when these quotes were made. Then write us a long synopsis with a psychological profile of the person making them in context. You will realize that 80% of them originated after a progression of discussion from other board members here and not from a statement quoted. The quotes were a progression of our discussions and not the other way around. As if the provider of the quote did not know first hand what to say. The word collector, control coil, etc., was coined by people here, not by the quotee. I have done this exercise and have noticed only one major point, these quotes are bugus and only designed to string people along when the quotes were made in the progression of a discussion done over a year ago on the two main threads. When you read them carefully, when you position them in the physical sense, you will realize there are contradictions there that only an non knowledgeable person making them could make because they do not realize the impact of one quote against the other. lol
Case in point. When the three stack TPU was first suggested on this forum to describe the TPU, this was from forum members. At that time I was totally flabbergasted because there was no f(*kin way in hell that this TPU exhibited any 3 stack function. There was absolutely no tangible proof of this besides the illusions people were seeing in the cut TPU. But wouldn't you know it SM comes in afterwards as gives his other now famous quotes. Give me a f(*kin break already.
You registered here on March 18th, 2008.
Your first post was about spherics.
Your second post was the long SM quote list. Big deal.
Your third post and you are already talking to Mannix.
So make yourself right at home here because I know now you have an ulterior motive here and it is probably to slam the same old bullshit in our eyes. This is what I would call a "plant".
Sorry but I don't buy it. Who the f*&k are you really. lol
Not everybody here sleeps at the switch.
You want to play with these great minds, well you'll have to pass through me first.
Guys, do you want to progress or do you want to go round in circles cause this guy just pitched you a nice U turn. Snap out of it will ya.
Sorry but I don't buy this bullshit. Forget what was said by SM and look at the device for what it f*&kin is already. There are more then enough CONCRETE observations available without having to rely on he said, or she said, who knows anymore. lol
Sorry but I am about to puke.
