Tesla patent 381,970 & TPU
Started by Turz, March 20, 2008, 08:40:22 AM
nrg00
Quote from: Turz on March 21, 2008, 04:45:20 AM
We know that one turn only nothing strange happens.... but if we setup this coil in pancake form we have a rotating magnetic field.....maybe something strange happens.... we must try this setup ad see if we are on the right track.
Turz
hes talking about the tesla pancake coil.
i cant help but think the opposite rotating fields is THE key to not only this device but anti-gravity in general. i bet the idea of connecting 2 bike wheels together and spinning them in opposite directions has probably already been mentioned a few hundred times, but that has got to be the reason for the gyroscopic effect.
i just saw this from another poster in another TPU thread, but i am inclined to think that whatever method was used to to rotate the opposite fields that it had something to do with tesla patents, whether the below image has anything to do with tesla or whether its a forum member's own idea that is not exactly correlative to the SM TPU i couldnt tell you. Is there a way to make the below example move the field in opposite directions? would that just be 2 of these with a parallel circumferences? or can you wrap 2 of these with opposing direction around the same core?:
Nali2001
Ok thanks EMdevices.
So.. since the 'good' images seem to be scattered around, could someone post these releases higher quality screen captures here please?
Many thanks!
Steven (and  noooo...)
EMdevices
Guys, don't get too excited about this Tesla patent.Ã,   It is well understood and he doesn't not claim free energy or anything like that.
The patent illustrates a 2 phase transformer, and it's driven by his 2phase AC generator.Ã,   Remember he was the AC guru and he's inventing all these extra devices to go along with his generator/motors.Ã,
What's interesting is that there are motor/generator setups where the stator 2-phase windings are connected together between the identical motors/generators.Ã,   You can imagine that his ring (stator) has a rotor inside and you will see that it rotates the rotor when the generator turns, and they will be locked , or rotating in step.Ã,   I've seen this in one of my engineering classes.
The infinite comutation is achived here due to the sumation of two perfect sine waves which change their phases with the rotation of the genrator, so in essence we have the equivalent of an infinite commutator.
A good book on electric machines would benefit some of you.
EM
P.S.  Nali2001, we can't upload large files anylonger on this forum, but I'll try and find the thread where some of these things are posted.
Localjoe
Quote from: Rosphere on March 21, 2008, 09:47:39 AM
Here is an interesting excerpt from page 3, lines 1 through 5:
Quote"...the currents are produced by dynamo-magnetic induction only, the same result being obtained as though the poles were shifted by a commutator with an infinite number of segments."
Jason and I were discussing this line last night.Ã,  The word, "only," popped out of this text for the both of us.Ã,  What makes, "dynamo-magnetic," induction different than your garden variety induction?
I wonder what, "a commutator with an infinite number of segments," would deliver.
I found another 'floating' point as well: from page 2, lines 64 ~ 69:
Quote"The construction of this or any equivalent form of converter may be carried further, as above pointed out, by inclosing these coils with iron--as, for example, by winding over the coils a layer or layers of insulated iron wire."
Nothing further is written about this point.Ã,  I wonder if, by "equivalent form of converter," does he mean iron both outside and inside, or iron only on the outside?
If the latter is true, outside only, then the wood or cork SM cores we hear of could still fit this patent as an, "equivalent form of converter."
Yet the phrase, "the construction... may be carried further," sounds more like the former is true, iron both inside the core and then 'further' wrapped on the outside.
There may also be three equivalent forms: inside only, outside only (SM), and both inside and out.
Jason said that the generator, with its four brushes and four spinning collecting rings, could easily be replaced by a more simple design that spins the magnets inside the stationary coils, (wound the same way.)Ã,  This would do away with the brushes and rings.
Since these brushes and rings are in constant contact, one might assume that there is no 'spark gap' type of activity going on here.Ã,  I am not 100% sure that we can do away with the brushes and rings because the metal atoms that make up these parts are not in constant contact; the ring surface is sliding past the brush.
However, Jason may be correct in viewing this generator as nothing more than a 90-degree phase-shifted pair of sine waves.Ã,  I hope so; building a generator without brushes and rings would sure be a lot easier to accomplish.
Must be on the same wavelenth man ... i found those oddities too.
A one coorilation i have come across that is too stricking to pass by is edward leedscalins "special electromagnet" He said for the upmost of efficency to be obtained there would have to be an iron "shell around the copper windings outside/superinposed on top of them. So lets take this for waht its worth
Iron core - copper coil -iron shell- Leedscaling claims this arrangment is most efficent electromagnet
Tesla- Annular iorn ring - primary 4 quadrant fine wire windings copper - Encased in loosly wound coarse iron wire.Ã,  He could mean this loose iron wire is the shell but thats too easy and he would have made some other notation to seperate it or he might imply to cover all the existing windings all the B's and C's with what we could call a tertiary coil of tightly wound iron wire.Ã,  Just wanted to throw that out there as well
"The thermal breakdown issue is mentioned" in this patent on the first page but is said to be avoided if the specs he lays out are followed.
Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Great finds man
Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Ã,  Joe
When you check out the electromagnetic motor patent that shows the dynamo machine it makes more sense. He shows the little diagram with the magnet position on the induction machine and then the current positon on the converter. I wanna say that the dynamo magnetic induction is devolped because the EM energy usually harvested from the poles on the dynamo /generator/motor are usually hooked into a circuit first where as here the energy gets directly transfered to the closed loop transformer from the windings on the machine. This may let a rotating feild devolp from the quadrants being fired in succession/ inerta
I can see how this secondary device would keep the dynamo going after it up to speed .. meaning we all pay power companies for starting there generatiors once in a while.. this is awful how bad were being raped now that im understanging it.Ã,  Once the dynamos/generators are started with the converter and brought up to speed the inital power source can be removed and this arrangment will keep producing.
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Nali2001
Hello EM I send you a personal message.
Thanks!
Steven
