The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
giantkiller
@Paul,
The rattle is very dangerous. :o I will not every turn the GK4 on again. It is copper on copper on iron. It is a 360 spherical Telsa coil with invisible bursts. A handheld EMP generator/weapon. It is suicidal for me to ever test with again.
But I got major cool with owning it! Quite the trophy. 8)
I hope that you don't experience any trauma. But it is the fastest education you'll ever have. I told IS to remove the other occupants from the house during the Audiohenge tests. :o
Copper on copper at 90 degrees at high speed creates a weapon. 8)
--giantkiller. Eyes wide open.
pauldude000
@Giantkiller
The audial effects do not even need a speaker. One (my first iron core), would audibly vibrate due to the induced rotating field. The rotating field moves charged ions in the air, causing air (sonic) vibration. At the right frequency, it is called a "Sonic Pain Induction Field".
This same rotating field, if spun fast enough, should exit the perimeter of the toroid into the surrounding environment. At this point of expansion, there is no discernment between it and an EMP. It should be the same for the field collapse upon shut down. I would hate to meaitysure field strength at these points......
If I am right in my speculations, at some point it should also affect local gravity, and local magnetic field distortion. (Don't ask, I am not going to tell. Some things truly are better left buried.)
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
pauldude000
@Chef
I did NOT know that. Interesting. That explains a great deal. Makes sense, as everything falls under an inductance or reluctance scale. (Everything is either a conductor or resistor to magnetic field propagation, in the same manner as electricity.)
:D Heres one for you. Assume that the field is limited in a TPU (which I doubt) to mach 1. What is the RPM of the field, if it is rotating 3" from the center point? Now, what is the field shape at 24". (Note: Consider drag effects, in that it is limited to mach 1, no matter the distance from the center point.)
:D  :)  ???  :o  :(  :-X
Paul Andrulis
vegasscorpion
Pauldude,
"How possibly to wind for specific tuning to a specific frequency.... EASILY....."
Could you explain this please?  Thanks
pauldude000
@vegas
Just that. :D
I haven't tested the notion yet. I will post the concept if it works, like I stated I would in the original post.
Paul Andrulis
