The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
forest
This is nice giantkiller but we need something deeper, something which unfortunately require quite deep knowledge in nuclear physic and ma thematic, which is beyond of my old tired mind.
Let me cite then in the hope of better understanding why 3 frequencies were used and why they are probably not required anymore:
QuoteEarly attempts to acquire the NMR spectrum more efficiently than simple CW methods involved irradiating simultaneously with more than one frequency. It was soon realised, however, that a simpler solution was to use short pulses of radio-frequency (centred at the middle of the NMR spectrum). In simple terms, a short square pulse of a given "carrier" frequency "contains" a range of frequencies centred about the carrier frequency, with the range of excitation (bandwidth) being inversely proportional to the pulse duration (the Fourier transform of an approximate square wave contains contributions from all the frequencies in the neighborhood of the principal frequency). The restricted range of the NMR frequencies made it relatively easy to use RF pulses to excite the entire NMR spectrum.
Applying such a pulse to a set of nuclear spins simultaneously excites all the NMR transitions. In terms of the net magnetisation vector, this corresponds to tilting the magnetisation vector away from its equilibrium position (aligned along the external magnetic field). The out-of-equilibrium magnetisation vector precesses about the external magnetic field at the NMR frequency of the spins. This oscillating magnetisation induces a current in a nearby pickup coil, creating an electrical signal oscillating at the NMR frequency. This signal is known as the free induction decay (FID) and contains the sum of the NMR responses from all the excited spins. In order to obtain the frequency-domain NMR spectrum (intensity vs. frequency) this time-domain signal (intensity vs. time) must be Fourier transformed.
http://en.wikipedia.org/wiki/EFNMR
Grumpy
Quote from: giantkiller on August 12, 2008, 04:06:49 PM
See what happens in space?
There is a polarization of the "medium" that occurs along the wire.  When interupted, the "medium" depolarizes.  Funny that optical depolorizers use a symbol that is also used to describe radiant electricity.
        -Frank Edwards
sparks
  @GK
Below is a diagram of one of Tesla's first "dipole" emitter/concentrator . Still involves a spark gap but his one was inside the enclosure.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
The delay is used for an input of 1 frequency to bifilars essentially gives multiple actions.
Collapse in a  DC field.
The bifilars I have are parallel wound, cu and steel. I should have 2 independant layers of cu. I twisted it up a little and achieved this artifact.
Copper lets go of the field sooner than the steel. 1 frequency. First action inbedded inside second action.
--giantkiller.
giantkiller
@Sparks,
I wrapped my fish tubing and nail spark gap in aluminum foil. Can work on desktop again around PCs. :D
But still multiple coil layers present a short. I say this for the benefit of readers. I could coil the audio rope around a pvc tube with spacing and really screw up the neighborhood 8)
--giantkiller. Bag o trix still good.
