Roll on the 20th June
0 Members and 18 Guests are viewing this topic.
CLaNZeR
Quote from: helmut on May 02, 2008, 02:30:05 PM
What we have learnd the last days is,that a heavy Wheel can be brought in motion
with just a fracture of the Wheel Weight.
So it might be possible,that the Stack of big Discs can be shiftet together ore streched,so they
are on the Pic with gaps between eachother.This funktion might result the overbalanced situation.
Hi Helmut
If we are simply back to shifting weights then this design is nothing new and tried many times.
I am intrigued to see the mechanism that Archer shifts that weight with very little energy, this is the key it seems.
I do not think anyone will dispute the fact that a little weight can shift a bigger mass. A good example is placing a Metal bar under a car with the pivot in the middle. You would push down with your body weight and not lift the car. Now move the pivot inwards so it is near the car and your body weight leaning on that bar will lift that car.
Exciting times ahead I reckon.
Come on Archer more teasers please. :)
Cheers
Sean.
http://www.overunity.org.uk
oak
Sean, are you suggesting maybe the disks (weights) slide on the rod?
In any case, as you say, we need to know more how he shifts weight with low energy.
Still the wee hours of tomorrow morning in Oz . . .
SolidCore
Hey guys, I'm new
I'd like to say that I'm very excited with the 20th of june announcement, and that I dearly hope that this device does do what the developer says it will and that the goverment and the oil industrys collapse over the pressure, I want to see a better world where everyone and everybody lives in an equal way, I don't like to see poverty in countries like India as much as I don't like to see a rich guy wielding a golf club outside of a dubai world's island... that to me is really disgusting (no one person needs all of that).
About myself, I'm a PHP/SQL Programmer, Aged 21, Male, Living in the United Kingdom.  I'm far from ignorant unlike most young adults and therefor like to present my respect and appreciation for the level of work and investigation and ideas presented at OverUnity, I never was good at science, my CC Grade GCSE proves that
I did test the concept of a weight on one of the fan blades, and Yes it almost reaches the top of the other side. If only there was a way to bounce the fan blade over the top...
Heres my idea.... this could work???
We  attach a metal pole sticking out of oneoft he fan blades, and face this against a circular track, the track allows for a one way direction only using magnets that repell the pole containing magnet that is also repelling the magnets in the track. where as the fan blade slides past 6'o'clock the pole sticking of of the blade is locked past a 'no return' point by the magnetic push and therefor slides the fan blade up and over the midnight position.
So my theory is that you could build a half track of magnets that are in no way would allow the magnet any rights to go backwards, pushing it over the top, it would have to slip inside of the track (slide into drop into) and therefor be physicaly not be allowed to bounce out of the system, once in, there is no doubt extreme pressure and flys back over the top.
It's just an idea, don't flame me for it.
Regards.
SolidCore
CLaNZeR
Quote from: oak on May 02, 2008, 02:57:53 PM
Hi Ed
Archer will probably correct me, but I think the basic setup is the same as many other gravity machines that have been around in the past.
At 1 O'Clock displace the balance by moving the weight out and it will drop the rotor down to 6-7 O'Clock. Then at 6-7 O'Clock bring the balance back to normal and then displace the balance back at 1 O'Clock.
As you have said the secret to be revealed is how to do that using less energy to reset the balance than to un-balance the unit.
Maybe moving to OZ is the answer! could do with some nice weather  ;D
Nice to see you still around mate.
Cheers
Sean.
SolidCore
Quote from: CLaNZeR on May 02, 2008, 04:14:54 PM
I have been sitting here with the fan and weight for a few minutes and decided to give that a try previous to my 1st post.. do you mean at the point it reaches 6-7o'clock gently rotate the device so that in theory it gives it an easier ride to fly over the top?
Well I tried and it succedes going back to the start ... however it would need to be on some kind of track system so that it flys back to the beginning once the weight reaches the top... and there is probably extra momentom in my arms trying to achieve this... so it doesnt really prove anything for me... so i too think thats one possibility if im right in saying thats what you mean sean.
Has anyone suggested using WATER? as a weight... and what it could achieve in this kind of system?
