Roll on the 20th June
purepower
Quote from: The Eskimo Quinn on July 10, 2008, 10:57:34 PM
just converting them now, then upload so around 1-2 hours for both
In the mean time you can go and read purepowers plans for a gravity wheel with leather straps and wood and shit he say it "will work"
What the fuck assclown? Where do I say this?
Horrible lies...
-PurePower
The Eskimo Quinn
where try these words
Kator,
I checked out the site you suggested.
What I am suggesting is a little different.
On the arm, there are 2 weights, one on each end.
If the weights are round, then when one end of an the arm is slightly
below the level of the axis, the weight can roll away from the center.
This would be gravity moving the weight.
This would also cause an over balance. And as has been discussed with
pequaide, a difference of 11% can increase the force from 9 to 10
kg's. This would allow for an over balance of 1 kg.
In the schematic, when the arm has rotated to the desired angle, if
the over balanced weight changes its' course, it can return to a
balanced position.
And as pequaide was nice enough to point out, Galileo has proven this
will not change the momentum of the weight.
The number 1 is the center of the arm and 2 shows the different path
the over balanced weight can take.
If the 2 path is followed, it would be similar to it moving like a
pendulum with a higher center of rotation.
This would move the weight to a position of balance with the weight
on the opposite end of the arm. This would allow for less momentum to
be used to keep the arm spinning. Then by rotating another 90 degrees,
the process can be repeated.
wow amazing considering he just spent 2 months telling me thre was no
energy gain from this type of arrangement, and above says its not
possible.
and goes on with
Kator,
It is okay. I was not sure if the idea was understood.
The ramp is like a slide. I think it would be good to have one on
each side of the frame.
A bar would be 10cm from the weight.
When the arm rotates, the ramp/slide would change the direction of
the weight.
It would not let the weight fall lower than 30cm from the center of
the axle. This is the distance the opposite weight would be from the
center. At the top of the slide, the weight would be 33cm from the
axle.
The arm would rotate for 45 degrees before the slide would change the
direction of the weight.
It could be lower. But for now, this will work.
"THIS WILL WORK " purepowers own words
my absolute favorite find of all, well we hope he shows us all his
claims of "will work"
for those who know him, you will love this one
@All,
If it takes you a year to understand this design, don't be surprised.
It is a new behavior. And because of that, it will take time.
But if you want to try it, you might find that easier than trying to
understand all the math. Then you can see what it is doing and
why it can work.
forget the math??? wow coming from a guy who claims it shows all, he
wants someone to just trust his words and build?? funny what you write
that comes back to bite you, no math, no build himself, statements of
"will work"
love this guy, caught out for the fraud he is
and this is the giant killer
Kator,
I posted a test a person could do to observe how that would work.
Even when I went to school for Propulsion Engineering, we did do
"hands on" work, Same went I went to school for Machining.
Yet while I could build a model, so can everyone else.
2 1inch thick, 8 inches wide by 8 feet long costs about $25.
A childs bicycle for the front axle, another $5 or $10.
And one 2inch by 2 inch board. The arm supports would need to be
secured to the base.
And then some bolts, 2 round weights and 4 straps of leather.
The leather an be used to make a cradle for the round weights. Easy
enough to hold them in a stable position.
And since I am looking for better work, will feel sorry for someone
that would say, can we only use math ? And the answer is no.
Without actually seeing something, you will never understand it.
  And if everyone thingks, hmmm, $40 and their own time is not enough,
then I know how much perpetual motion/over unity matters to them.
Only reason I did it was because of problems my ears have caused me
among a few other things.
Think everything is straightened out now.
gottat love that, instructions costs and saying you cant use math, i
know a few people that will be jumping on his lying ass right now
saying build it you lying prick, all that time trying to debunk archer
and you have made the same claims using the same terms and never even
showed one build of anything.
Boeing? looking for a job?machining, propulsion engineering student
for an oil projects company all at 21, you are the man. show us your
machine. show us what you said "will work" and said today is
impossible.
funny how i remembered that thread
http://www.overunity.com/index.php/topic,1995.120.html
Bye bye little boy
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
shakman
Quote from: purepower on July 10, 2008, 11:27:41 PM
Horrible lies...
-PurePower
@PP
Dude, find another thread already. Actually, how about another forum? Or maybe just another planet.
You came here with a grudge. You then turned on your heals claimed to be only here to help. You made a few posts to appear to be helping people (but none of them were really helpful, even to me and I never studied physics at university level). Then you put on your blinkers and type anything that could remotely dismantle the possibility of OverUnity, then claim to be for OverUnity. You're like a kid that wants to use a swing but you're to scared to climb up on it. This forum is about discussing ways to acquire OU (I thought the URL gave that away). Deal with it.
You make no contributions of any worth here. It's way past your bed time anyway. Move along.
shakman
therealrasta
Quote from: exxcomm0n on July 10, 2008, 11:15:58 PM
@ PureP
Build me anything using no energy.
:D
Hmm.. I mentally built the worlds largest left handed cigarette..  Oh that took electrical impulses in my brain to do that.. Well I guess it's not possible.. We should call this the exxcomm0n effect.. :)
Nothing wrong with saying your peace man.. Especial since you tried to be cool and just let bygones be bygones and they still presisted in a merger attempt at belittling you.. So I say your in the right with your post.
@ Archer
Just noticed one of your vids are up.. Gonna go watch it now.. thx for sharing and good work.
purepower
Quote from: The Eskimo Quinn on July 10, 2008, 09:25:54 PM
i found the perfect design for a wheel, i have posted it on this thread, it is the second one "gravity only", i think you are gunna love this to death.  ;D  ;D  ;D
from an engineer who has guided many people
http://groups.google.com/group/magdrive/browse_thread/thread/af227943869b6355
Wow Archer, you have stopped to an all time low. I was not referring to blessers wheel in the the first bit, and
EVERYTHING FOLLOWING IS A COMPLETE FABRICATION. I NEVER SAID ANY OF THAT.
Desperate measures form a desperate man.
-PurePower
