elemental rod
Started by slayer007, April 25, 2008, 01:16:11 PM
Koen1
Quote from: zapnic on June 24, 2008, 03:54:42 PM
http://tech.groups.yahoo.com/group/usa-tesla/
mhhh maybe invate Dr. Schwartz to come here?
Zapnic (or anyone else), that sounds like a great idea! :)
I can't access my old Yahoo account at the moment (since I forgot the password
and am trying to find it, otherwise will need to make new account which I don't
really want to do, etc) so I can't contact dr. Schwartz through the yahoo group...
Can you or anyone else on here perhaps invite dr. Schwartz to join this thread?
The info he gives in the non-members section of the yahoo group (the stuff you
quoted in your posts) is quite interesting but still very vague.
From my 'research' into Tesla's work with his "Radiant Energy Shield", his
"purple plates" experiments, and (seemingly) related work I know
Tesla did many experiments with all kinds of metal wires and/or plates of
various metals, often "treated" and/or coated with one or more other metals,
which can cause all kinds of subtle effects (weak photovoltaic surface effects,
diode-like voltage bias/asymmetrical resistance effects, lowering of the emission
thershold, even increasing/decreasing/otherwise altering the magnetic field
'geometry'/'strength' when used in a coil, etc) in the right circumstances.
And he also experimented with many different types of discharge and many
different frequencies. A lot of his devices involve various harmonic oscillations,
and he seemed to be convinced of the existence of longtitudional em waves
(which of course established physics does not agree with but hey).
Some of the stuff I was personally interested in was his use of aluminium plates
which (as far s I could figure out) treated with various chemicals during his
experiments, in order to obtain a thin layer of a different element (metal) on
the surface of the aluminium plate. Or on its surface and integrated into the
surface layers of the aluminium crystal lettice, more likely. Anyway, this
is an old method I know from old 1930s electrophysics books where it is
(sometimes) mentioned in respect to its value in decreasing the emission
threshold of certain metals, but I believe Tesla figured out some other usefull
effects he could achieve by surface treating various metals.
Of course aluminium was only one of many metals Tesla tried, and from the
papers I read I got the impression it was not as good as some others...
(oh sorry, I'm ranting again ;))
Well, in any case, I am very interested in dr. Schwartz's work and would
certainly like to hear what he is prepared to divulge about his Tesla radiant
energy plate device and its underlying principles. :D
th3jester
I'm excited to see what comes out of this interesting situation..... :o
A little note about the MIB and stuff like that.....
I won't usually say much on the internet or even discuss what I am doing. Mainly because of the people that would want to stop it. Although I am not afraid of them and will post and produce anything I able to create that actually works.
Rods producing AC??..... looks a like a tuning fork battery. The TFB!  ;D
pese
somes that i found 2005 over this (german)
its are 73 an 74 DIFFEREN elemts molten in the rods
it was talken from neutrinos !
in night time , an little bit lower efficence (i remember)
sp thas are longer misteriosly.
here my (recovered) notes
30004   21.07.2005        ,Trier G.Pese
30004   ----------
30004   Habe ueber franzoesische GOOGLE Seiten eine recht seltsame Geschichte
30004   entdeckt von der weder deutsche noch englische Texte berichteten , also
30004   nicht "wahrgenommen" wurde. Es handelt sich um 2 Staebe vondenen einer
30004   (angeblich aus 73 verschiedenen Materialien besteht , der andere aus 74,
30004   ausser Schalter und Kondensator (und den ca 18cm Staeben ist nicht enthalten.
30004   /2 Videolinks , sind in hier unter Nr # ..... hinterlegtem Text enthalten.
30004   Die Rede (Video) war ueber Neutrionen , 24 Stunden Energie , durch Umsetzung
30004   des Sonnenlichtes, wie auch Kosmischer Strahlung.
30004   Explizit wurde die bekannte Tesla-Erfindung von 1901 erw?hnt , NUR dass
30004   hier im Gegensatz keine Metallplatte (beschichtet) gegen ERDUNG
30004   (ueber Kondensator) arbeitet sondern HIER die 2 Elektroden /aus unterschiedl,
30004   Material.  Da Teslas Erfindung dahinzielte dass die Platte Neutrionen
30004   (oder Positronen ??) anzog und die "ERDE" den "Gegen-PART" . Ist hier
30004   lediglich eine "Weiterentwicklung" des Japaners , die "funktioniert"
30004   Da bereits ueber blossen Antennedraht statische Energie aufgefangen wird
30004   (100 Volt pro Meter ??) Waere es interessant ob nun POS oder NEGATIVE Soannung,
30004   respektive ob nicht durch andere Auswahl genau 2 gegenpolige Spannungen erzeugt
30004   werden koennen , da in Kosmos anscheinend Positronen und Neutrieonen vorhanden
30004   sind.  Die ist fuer mich von Interesse um hier die Arbeit des Japaners
30004   besser nachvollziehen zu koennen.
30004
30004   Seiten sind unter $fe80  aufrufbar  /S6/
www.translate.ru
30004
Koen1
Great pese,
but I guess you missed the quote from dr Schwartz where he says
the story about 73/74 elements was just a ruse?
