How do you turn off a tpu?
Started by sparks, May 14, 2008, 10:07:23 AM
sparks
   Below is a diagram of an energy sink.  You can get a safe one in the states all made for you at novelty stores.  It's called a plazma bulb.  It is the ones that have the purple strings of light that rotate all around the inside of the glass bulb until you touch it.  Then the purple strings are drawn to your fingertip and you see red light wherever you touch the glass as the energy from you is pulled towards the plazma created by the spark gap between the inside of the glass and the emitter in the middle.  I heard from someone that if you use aluminum foil you get a pretty fair amount of red light.  More light same amount of juice to the aether fridge.
  Thanks FB for the aluminum foil experiment!!!!
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
