I have a working Bessler wheel in my simulation !
Started by hartiberlin, May 19, 2008, 08:36:06 PM
hansvonlieven
@steve,
Yes, polygons are a problem. Fletcher found this out too.
@erick,
You have run into the same trouble as I did. I think the moment you have 8 kinetic bodies in the simulation the thing goes haywire. It cannot cope with that many moving parts.
@ all,
One of the problems I have found is that it is extremely difficult to place parts accurately. You really have to get into high magnification to see it. This throws the whole thing into disarray. I had one simulation today that behaved irrationally until I found the culprit to be an imbalance in the system caused by poor placement of components.
At any rate it's been fun, sort of anyway. Or has it? ???     ;D
Hans von Lieven
AB Hammer
Greetings Stefan
The test is done and the videos sent plus one other that I did a slight change on.
Alan
fletcher
Hans .. when you have a WM screen up & want to place parts you will find a grid reference bottom left of screen i.e. x & y co-ordinates for the object or point - manually over-type in the correct co-ordinates & you will have perfect placement each & every time - these sorts of problems are 'builders error' but usually can be avoided.
P.S. if you are placing points or objects around the circumference of a circle then place the first one at 3 o'cl - then change the degrees of rotation of the background circle [bottom box, middle to left of screen] - anchor the background wheel & place another part at the 3 o'cl grid reference & repeat for however many segment divisions [degrees] you want.
Dgraphic911
I need some help, i just downloaded WM and made a quick object/pendulum wheel and it just keeps turning, do i have to turn something on, Friction Etc. or is it preset to real world terms, Also since its demo and i can't save how do you show screen shots the best way.
I can see why everyone loves this thing, PM models that work in seconds,  but seriously how do i stop m,y wheel from spinning
fletcher
Turn World>Air Resistance>Low Pressure on - this creates some approximation of real world system losses [quick & dirty testing] - to show here take a screen shot Alt>Print Screen [hold both at same time] & paste into MS Paint [.jpg] or as I do into Irfanview & crop & save as a small .gif file for posting.
Read the tutorials - they are quite helpful.
P.S. I'm not an expert user - just played around a while with it & had help from a friend who is accomplished with it.
